-   -   Turbo the SC 3.0 or Source a 3.3L??? (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/453960-turbo-sc-3-0-source-3-3l.html)
jcc911 01-28-2009 09:21 AM
Guys,
I have been going back and forth on this daily and need some advice on which route to take in order to finally have a turbocharged 911.
So the question is do I TC the 3.0L with a 930 CIS, MK 993 header set-up and muffler, and K27 (plus all of the add ons like fuel pump, oil drain/scavange, etc)
OR
Source a 3.3L?
The one good thing about my current engine is I recently did all of the head studs and a top end (Thanks for the help M&K). I ported the heads for twin plug (that is not currently in use), and many of the components have been powder coated to my liking.
Obviously with the 3.3L I would have an engine already tubocharged and was set-up to do so. I may have found one of a reasonalbe price, but some assembly is required. Also I would probably have additional expense with headers, turbo, but this could be done down the road.
Thanks for the advice! Cheers.
lite75 01-28-2009 11:13 AM
Lower the compression and use the 3.0, your heads have better port sizes than a stock 3.3 and you already know the condition of your engine.
jcc911 01-28-2009 11:30 AM
Thanks for the insight.
One bonus for the 3.3L is I have the compression data on it as well and can verify it is in good shape. I am certain it has less miles than my SC engine, which only has 87K on it.
