Jesper's Avatar
Originally Posted by WERK-I View Post
Jesper,
Do you know if the master cylinder was upgraded when the rotors and calipers were upgraded? A photo may help.
Since these are aftermarket rotors, I wonder if it is a question of rotor thickness versus brake caliper. It looks like the pads are new.... Maybe the pads are fully retracted when you turn into a corner and can't retract any further? Also, have you checked to see if there is some looseness in the front wheel bearings?
Since the early 930's used 911S calipers/rotors, the Boxster "upgrade" would be better than the 911S's.
Hi WERK-I
Where do I locate the master cylinder? I have checked the wheel bearings they are no looseness at all.
Thank you all for the replies, Ií am so thankful.
Best regards
Jesper, Denmark
Old 02-01-2009, 09:30 AM
Me like track days
Craig 930 RS's Avatar
If not, the MC will be asked to push a LOT of fluid - and the pedal will always feel soft.
This is completely separate from your current problem, but if the MC is original, I would change it.
But - I do not know the compatibility with earlier smaller-braked 930s - others here probably will -
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 02-01-2009, 09:55 AM
Forced Induction Junkie
WERK I's Avatar
Jesper, it is located in the front trunk area. Just line yourself in line with the steering wheel and look straight ahead towards the bulkhead and you will see a white plastic liquid reservoir on top of it. The master cylinder will have two metal lines attached to it.
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 02-01-2009, 10:00 AM
Jesper's Avatar
Hi Craig, that is why I will locate the MC and take a picture of it.
I am aware of, that the problem with my breaks is some ware else, but I would like to know if the MC are upgraded.
Best regards
Jesper
Old 02-01-2009, 10:03 AM
WERK I's Avatar
Oh, almost forgot. You will have to remove the carpeting in the trunk to see all of the master cylinder.
Dave
Old 02-01-2009, 10:07 AM
If it has had new brake pads installed recently, then that could be your problem. The outer metal edges of the pad body sometimes need minor skimming to slip into the caliper slots. I've seen were new pads are literally crammed in those caliper slots and then cause rubbing and binding because the pads cannot release from the rotors.
Old 02-01-2009, 10:22 AM
Turboo934's Avatar
On 76 Turbo the master cylinder is under the front splash pan, covering the rack on the bottom of the car. Early cars came with 19 mm , it will have 19 stamped on it. The one you want is Merc. Benz with a 23 mm stamped on it, will try to find the part number for you.
Old 02-01-2009, 10:51 AM
