7.0:1 > 11.3:1
G50-50 in the classifieds
Noticed this in the classifieds. Perhaps somebody here is interested. (No affiliation to me):
F/S: G50/50 930 5 spd. Trans.w/ LSD - $7,000.00
Old 01-30-2009, 08:18 PM
OFF THE BOOST PIPE NOW...
A930Rocket's Avatar
Is that a straight bolt in? No mods needed, except maybe clutch pedal/mechanism? Good deal if it is.
Old 01-31-2009, 05:50 AM
vmb vmb is offline
vmb's Avatar
FS: RARE, G50/50 5-speed with LSD. Yes, THAT one.
so are there 2 of these for sale on the East coast at the same price? The above thread says that w/o torsion bars it'll fit right in. If only we weren't buying a house next week........
Vic
1979 930 with Rebel coilovers and many more parts on shelf to be installed.........
Honda Odyssey minivan parked under the turbo
former Tony//Kart shifterkart owner
Old 01-31-2009, 08:52 AM
Me like track days
Craig 930 RS's Avatar
MAJOR work to install one. My 930 has one, you should see the bill for parts and labor.......2 owners ago.
I'd never do it!
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 01-31-2009, 09:59 AM
A930Rocket's Avatar
Close on the house, get the equity line and it's your!
Old 01-31-2009, 04:55 PM
I did it on mine, very costly about 20k, well mine is special Paul Guard gears and chromoly differential, motorsport steel synchros, labor is included at that number as well as the KEP pressure plate motorsport clutch etc, hydraulic pedal cluster. It is nice but a re-geared 930 box is also nice, for what it is worth you could do a six speed for less, as they are cheaper to buy, a lot more of those were produced.
Lincoln Phillip
87 930 Motec EFI M600 G50/50 TurboKrafted Hell Hound.
Jeep, Chrysler, Dodge, Ram, SRT & AEV Dealer pm me for your Mopar needs.
"the 930 is THE CAR that started my PORSCHE love affair..." Magnus Walker
Old 02-01-2009, 07:06 AM
Me like track days
EXACTLY what is in mine - I think it was 7k parts + 12k for labor about 10 yrs ago.
Old 02-01-2009, 08:16 AM
~130hrs (16 working days) to rebuild and install a G50/50?
Old 02-01-2009, 01:12 PM
Me like track days
Patrick Motorsports Feb 14th 1997 - parts
Transmission $4,100
Shifter $265
Hydraulic pedal assy $435
Misc parts $382
Trans Mount $150
Starter ring gear $140
Install - including fab linkage and motor mount March 11, 1997:
Parts: $1383.80
Labor $5999.88
Total about $12,500 .......12 years ago when the transmission was $4100 and labor was probably $80 or so.
Old 02-01-2009, 02:10 PM
That makes sense. The way your first post read was $7000 for parts PLUS $12,000 for labor
and no one in their right mind would pay $12k to install a clutch, pedal cluster and transmission in a 930.
If I could find a good G50/50 today for $4100 + additional parts and labor it would already be in my car
Old 02-01-2009, 07:05 PM
Craig that is a deal for a G50/50, even then. Are you sure it is a G50/50 and not a G50? The reason the G50/50 install cost so much is that the case has to be machined as well as the main shaft. I guess I had quite a bit of custom work done to the trans as well.
Lincoln Phillip
Old 02-01-2009, 08:45 PM
Wer bremst verliert
JohnJL's Avatar
I just paid the exact same as Craig for the exact same stuff 3 months ago.
As far a it being a bolt-in, it depends on what you drive. An SC or earlier requires cutting and welding, even with Patrick's adapter and mount bars.
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 02-01-2009, 11:54 PM
Wer bremst verliert
JohnJL's Avatar
Craig, did you mean 1997 and 12 years ago or 2007 and 12 months ago?
Old 02-01-2009, 11:56 PM
Me like track days
Sorry for not being clear, I am seriously sick, and thus"out of it".
This was all done in 1997 -
The thing I love about the G50 is in combination with the WEVO G50 shifter (by the way John, this is a HUGE improvement over stock, HUGE) it shifts exactly like a modern car.
Old 02-02-2009, 02:25 PM
lite75's Avatar
The G50/50 and std G50 units all require the same machine work, The clutch housings are identical. The Ring and pinion design is the biggest difference.
75 930, 76 930, 83 SC EFI turbo
Old 02-02-2009, 04:14 PM
lite 75 I started to amend my post but work interupted. What I meant to say about the cost of the G50/50 was the availability or lack thereof of the turbo trans drove the price up.
Lincoln Phillip
Old 02-02-2009, 05:10 PM
lite75's Avatar
To fit in a 78 up 930 it needs the clutch housing shortened along with the mainshaft or you can install a G50 torsion tube. For installing in a 77 or earlier 930 or early 911 even more. You can shorten the housing along with moving the motor back or using a G50 torsion tube. I went with the later type option to keep the motor as far forward as possible. The 78 and up 930s already have the motor moved back to make room for the rubber damper on the clutch disc thus the long clutch housing.
Then there's the coil over option also...
Old 02-02-2009, 05:33 PM
Lite, inform us on the Coil over option...
88' 930
03 Tacoma, 04 Duramax, 06 R350 Benz
If you are traveling at the speed of light & turn on your headlights, does anything happen?
Old 02-02-2009, 08:33 PM
Me like track days
My motor is moved back about 2"
Old 02-02-2009, 08:38 PM
lite75's Avatar
Craig,
Is your clutch housing shortened?
Akila,
With the coil overs the torsion tube is completely cut out of the way, reinforced at the tube ends and gusset plts added to the shock towers.
I gave myself enough clearance to run a std length G50 and still retain the torsion bars.
Old 02-02-2009, 09:01 PM
