3 restos WIP = psycho
kenikh's Avatar
There are some modern tires out there that mean 245 can be enough. My buddy's 600HP beast has a ***** of a time breaking his 245 Bridgestone RE11s loose, even with a 5 speed G50.
For the fronts, I prefer the narrowest tire I can run. I'll pay more for grippy compound that allows for a narrow contact patch and telepathic, light steering.
I'll take 175 Avon CR6ZZ tires on 4.5 Fuchs over just about any front combo for grip and feel.
Sent from my Nexus 6P using Tapatalk
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 06-19-2017, 07:26 PM
kenikh's Avatar
FWIW, I run 205/16 and 245/16 RE11s on my 930 and they are AWESOME.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 06-19-2017, 07:29 PM
proffighter's Avatar
Toyo R888's 235/17 front and 255/17 on 9/10". Very nice (if I even could remember :-) )
Roland
930 Turbo '81 Too many modifications to list
Old 06-20-2017, 02:58 AM
Turbo Powered Snow Blower
^^^ Kenikh, How are the RE11 when cold? I stayed away from track tires on the Porsche because of the extremely poor performance in the cold I discovered with Hankook Ventaus (sp) on my mustang.
It's literally like wearing flip flops on an ice rink when cold.
Derrick
Old 06-20-2017, 05:04 AM
kenikh's Avatar
They're street tires! Cold traction is great.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 06-20-2017, 07:38 AM
kenikh's Avatar
The Pirelli Trofeo Rs are insane, as well.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 06-20-2017, 07:41 AM
every day, four cups usually takes care of it.
Old 06-20-2017, 07:52 AM
ahenthus's Avatar
Not trying to hijack the thread but it'd be a waste not to ask this with all the tire experts on here. My rears are wearing on the inside. I don't track the car but I believe a po had it set up for the track. It has never been tracked to my knowledge. The rears are 315 Sumitomos. Would this be too much camber causing the wear?
Old 06-20-2017, 09:33 AM
Yes, other guys with street alignment will chime in there rear setting.
Rahl
Old 06-20-2017, 10:27 AM
Mark your car must ride and handle like the shizzle on rawknees nizzle.What do you figure you have in just the suspension as far as dollars?
Sent from my SM-N910T using Tapatalk
Old 06-20-2017, 10:41 AM
Work in Progress
Rich76_911s's Avatar
HA HA HA I had the same thought.
"The reason most people give up is because they look at how far they have to go, not how far they have come." -Bruce Anderson via FB
-Marine Blue '87 930
Old 06-20-2017, 10:58 AM
Anyone ever feel overtired?
Too much neg camber or driving in a straight line for too long.
Derrick
Old 06-20-2017, 11:02 AM
full quack's Avatar
Send a message via Yahoo to full quack
Hey there Kevin,
Without the tires & wheels or alignment/corner balance, I'm guessing around 4K, but that's just a wild ass guess, and it was about 6 years ago!!!
This particular final set-up is the third attempt to get it right. I first tried to do it on the cheap down low....total waste of money & time. So I tried to step it up a bit the second time around, only to end up with a harsh riding, ill handling, squeaky car.
So finally decided to do it right, once and for all...could not be happier. Lesson learned is that there are no short cuts, right is right....cheap crap is cheap crap.
If the car was a track car, I would have gone with polybronze bushings and coil overs, but it only sees the street. So the added cost for only a minor improvement on the street, made no sense.
Mark
Old 06-20-2017, 12:02 PM
The saying goes: you can never be too rich, too good looking, or have too much tire
Unfortunately I only have 265s on stock wheels however.
07 Exige S
Old 06-20-2017, 12:10 PM
I recently upgraded from Bridgestone 235/45-17 and 265/40-17 to the new Firestone Firehawk Indy-500's in 235/45-17 and 275/40-17 and love them. They are mounted on Ruf 9x17 and 10x17's
on a 86' 930.
Old 06-24-2017, 04:01 PM
Can u post some pics?
Sent from my SM-P607T using Tapatalk
Old 06-24-2017, 05:15 PM
kenikh's Avatar
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 06-24-2017, 08:25 PM
Rahl
1/2 degree of negative camber works well with 315mm or foot wide 30 series rear tires. The tread seems to wear evenly side to side even in S.Florida where curvy roads pretty much don't exist.
Old 06-25-2017, 11:51 AM
David's Avatar
Still finalizing my final tire change plan. I have decided to try 225/45-17 front tires which means I'll need some new narrower inner wheel halves to change my wheels from 9" to 8.5" for the narrower tires. I have not decided whether to stick with the current 315/35-17 tires on 11.5" wheels or go with 275/40-17 tires which will also require loosing 1/2" of wheel width.
Anyone here running 225/315 front/rear combo?
2014 Cayman S
2011 Cayenne Turbo
Old 09-12-2018, 08:15 AM
pdqcarrera's Avatar
Originally Posted by David View Post
... Anyone here running 225/315 front/rear combo?
That combo would certainly yield an understeer I personally wouldn't like at all.
Old 09-12-2018, 02:57 PM
