wtb scavange pump mounting plate
Any of you out there with the mounting plate that mounts to the engine then the pump mounts to that? Let me know thanks
Ben
914-6 2.4s GT tribute.
914-6werkshop.com manufacturer of 914-6, GT, Conversion parts
Old 02-04-2009, 09:03 AM
iamchappy's Avatar
I didnt use the mounting plate on my SC engine, just the pump. Drilled and tapped the end of the cam and use a pair of cap bolts.
914 6 Turbo twinplug 3.12
87 924S
Lexus SC400
Lexus LS400
Old 02-04-2009, 07:12 PM
what drives the shear pin on the pump just the heads of the bolts?
Ben
Old 02-05-2009, 03:37 AM
iamchappy's Avatar
Yes..... I guess roll pins can be used in the pressure holes that are in the cam if the shear pin will engage them.
87 924S
Lexus SC400
Lexus LS400
Old 02-05-2009, 04:42 AM
Like chappy said, the heads of the allen bolts are what turn the pump. Just make sure you use some high quality bolts as mine were almost worn off when I pulled my engine appart.
I used SC cams, and had Doherty install a pump bearing on the back. He then drilled, and threaded two holes for the allen bolts. You probably wouldnt even need the belt wheel as the pump only drives on the bolts. Just get a pump, and install spacers in place of the mounting bracket.
John A.
1979 Porsche 930: 3.4L, SC cams, Twin plug, Leask WUR, Custom SSI turbo exhaust, Tial WG, K27HFS, and we can't forget the Zork (short lived depending on my homeowners assoc.)
05 Boxster S: For the Track.
06 Dodge Ram 2500 Power Wagon: Tow Vehicle
Old 02-05-2009, 07:06 AM
