Twins are more fun!
JMA-RUF's Avatar
Aftermarket pistons?
Who on here is running some aftermarket forged pistons in their 97mm cylinders?
What kind of C/R are you running and what's the difference in pre-boost response compared to the factory 7.0:1 C/R?
I'm considering the possibility of having a set of 8.0:1 JE's made up for my 97mm barrels.
I'm also looking at having a 75mm throttle body fitted to my motor, however, I'm not quite sure how the OEM idle contact circuitry will work with an aftermarket throttle body. Any suggestions?
James
Carrera TT
(3.3, Protomotive MAP ECU, EFI, GT2 EVO CAMs, Twin Plugged, Twin Turbo's)
Old 02-06-2009, 02:54 PM
Wo ist die Rennstrecke?
DonE's Avatar
Lots and lots of JE's running out there with no problems. I have 8.0:1CR.
Old 02-06-2009, 03:01 PM
Twins are more fun!
JMA-RUF's Avatar
Thanks, DonE. What kind of boost are you running at 8.0:1?
James
Carrera TT
Old 02-06-2009, 03:18 PM
