G50/50 Lube
I went looking in the archives to find the lube folks are using in the G50/50, but did not find an answer. What are using? SWEPCO, if so which one?
Thanks,
Bill
Old 07-22-2009, 02:12 PM
Metal Guru
911nut's Avatar
Does it have a limited slip?
I use Mobil 1 LS 75-90. I tried Mobil 1 Delvac but I the diff didn't like it much.
Paul B.
'91 964 3.3 Turbo
Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb
Old 07-22-2009, 04:15 PM
Manassas, VA
lucittm's Avatar
Bill,
My G50/52 has the limited slip differential and I used Mobile 1 Delvac. I'm not sure what was in there before I changed it. I noticed no change in performance or problems. Here is a link for the source I used:
http://www.lufteknic.com/Merchant2/merchant.mvc?Screen=CTGY&Category_Code=lubricants
1 Gallon of Delvac 75W-90 was just about right. Just make sure the oil meets the Porsche specifications:
API GL5 for mineral oil or Mil-L-2105B for synthetic oil.
Mark
1991 964 Polar Silver Metallic Turbo Coupe
Old 07-22-2009, 06:40 PM
Metal Guru
911nut's Avatar
Both LS and Delvac are rated GL-5.
Many swear by Delvac. Maybe I got a bad batch, I don't know.
I was fairly certain that the Delvac was going to destroy my diff; it just wasn't slippery enough.
Paul B.
'91 964 3.3 Turbo
Old 07-23-2009, 02:50 PM
Thanks, Delvac it is. Mine is also a limited slip.
Old 07-23-2009, 03:42 PM
Metal Guru
911nut's Avatar
Bill, post your results when you do the change. I'm curious to see how Delvac works out for you...
Paul B.
'91 964 3.3 Turbo
Old 07-25-2009, 10:25 AM
