throttle linkage blocks at 85%
Hello,
during some upgrade work on my `87 930 I noticed that the throttle can be opened only up to ~85%. The linkage touches the engine tin. Seems I was lucky that the throttle wasn`t blocked at open throttle during driving. My car has a G50 swap, maybe thats one reason for this problem. The engine position is slightly more to the rear end then it would be without the G50. Anyone has a picture or drawing showing the throttle linkage going through the engine tin? Would be very helpful. Further, how much power I have lost approx. with this limiter? Falk |
As I know you like pictures, maybe this helps
to understand my problem. I can reachthis position pushing my pedal full down: http://www.alumex.de/930/TP85.jpg this would be WOT: http://www.alumex.de/930/TP100.jpg here a sketch where I suspect the reason: http://www.alumex.de/930/TPdrw.jpg and here a picture from my linkage at engine tin: http://www.alumex.de/930/TPlink.jpg again, a picture from the linkage going through the engine tin would be helpfull. thanks Falk |
Since it's not stock, you'll just have to wing it and figure out what works.
To get my Carrera TB to feel right, I had to cut and weld all the bell cranks to get the right positions. Your problem might be as easy as just opening the tin a little, but if the angle is really like your pic you might need to modify some bell cranks too. |
Here a picture from the linkage at 85% throotle position.
I suspect, as the engine moved backwards during the G50 swap (not my work) the linkage was not adjusted/bended correct. I will try to bend the linkage for a better fitment first. As asked before, a picture of a fitting/original linkage would help a lot. http://www.alumex.de/930/TPlink85.jpg Falk |
When I put my G50 in I had to completely make a new linkage cause the motor was moved back .625". It took some time.
I like to bring this back up, as my car is still not ready,
but hopefully soon. What do you think how much power was not used? I rechecked that all, the blockade is at 75-80%. Means, I used max. 80% throttle all the time. Would that result in 20% less power? thanks Falk |
| All times are GMT -8. The time now is 02:19 AM. |
