boost sensor characteristic needed
Hello,
I am working on a project and need the characteristic
from our original 930 boost sensor.
I have a `87 930, I think there are only 2 sensor versions.
I tryed to map mine, but there is no resistance change
under pressure. Seems mine is broken.
Maybe one of you took the data already and can help.
I don`t want to buy a new sensor, I don`t need this part
on my car anymore.
Falk
87 930 bblk/blk
88 3.6 white/blk
Old 02-19-2009, 08:23 AM
mark houghton's Avatar
Just to clarify what you're looking for: The boost sensor (that inputs a signal to the dash mounted gauge?
Are you looking for a map of resistance changes as the sensor is exposed to variations in boost pressure (assuming that's how these things work)?
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ.
Old 02-19-2009, 06:16 PM
0.0 Bar 5 - 13 Ohms
0.9 Bar 117 - 129 Ohms
Measures on a original 1980 sensor. I belive the curve is linear but why I didn't record that I don't know.
Jim
Old 02-19-2009, 06:47 PM
exact that is what I am looking for.
I tryed to do this by myself, but as said above,
my boost sensor do not change resistance under boost.
Thank you Jim, I saw your nubers while I searched here.
I don`t think the sensor has a linear curve.
I am in contact with VDO for the curve, but they are slow.
Falk
87 930 bblk/blk
88 3.6 white/blk
Old 02-19-2009, 11:23 PM
When you say you have no change under pressure is the measured resistance a value, zero or infinity? What are you using for a pressure source?
I measured mine to see if it was worth using as the source for a digital boost gauge and it is not as the sensor maxes out a .9 bar. I used a pressure regulator and a digital pressure instrument. I believe I didn't do a curve after discovering the sensor maed out at .9
Mine being old was very dirty (resistance wise) especially at the lower end. That's why the measurements are given as a range. I attributed that to age and wear.
If you get a curve from VDO please post it or send it to me in a PM. I'd like to have it on file.
Good luck.
Jim
Old 02-20-2009, 07:22 AM
hello Jim,
the measured resistance was ~zero with a mechanical
multimeter.
I used a pressure regulator + mechanical pressure gauge.
Pressure source was the companys compressor.
I will get a second boost sensor next days to check what was wrong.
Even with my good contact to VDO, I am not sure if they have the
characteristics available.
When I have the data, either measured by myself or VDO data,
I will post them here.
Maybe someone here has time and equipment to measure
the boost sensor characteristic to compare later?
Falk
87 930 bblk/blk
88 3.6 white/blk
Old 02-20-2009, 09:58 AM
