porsche question
hi.. guys i have a 1979 porsche 911 sc and im thiking about putting some 17 inch c2 turbo twist rims on her will they fit. also will my speedo make a difference are not. and will it make my car faster are slower thank you for all the help thanks.
sylvester
Old 02-07-2009, 03:38 PM
OEM rims will fit but require the use of spacers. Aftermarket rims will have the lower offset that will bolt right on. However, the aftermarket rims will also be a little heavier. As for speedo variance, if you get the same overall diameter as your current setup, it should be fairly accurate. Most likely, the larger wheels and tires will make your car slower.
Bryan O.
77 930
88 Carrera cab
14 535i M Sport
Old 02-07-2009, 03:42 PM
porsche question
ok.. thanks for your help.
sylvester
Old 02-07-2009, 05:14 PM
