part number help for oil lines
I need to find the part numbers for the turbo oil feed line complete from engine to turbo and the from the drain to the scavange pump. I have looked online and simply can not find it.
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 02-04-2009, 07:23 AM
Manassas, VA
lucittm's Avatar
Ben,
I have a turbo drain to scavenge pump line if you need it. It is P/N 930-107-338-03 (List $194.50). It has been re-silver soldered $50.00.
The turbo oil feed line from the engine is P/N 930-107-125-07 (List $64.25).
The two lines from the scavenge pump to the oil tank are P/N 930-107-336-04 (List $200.25) and 930-107-336-05 (List $35.25).
Mark
1991 964 Polar Silver Metallic Turbo Coupe
Old 02-04-2009, 09:28 AM
Ok thanks for the help on this I now have the stock turbo feed line which is what I really wanted now I need the fittings for each end of the line can anyone help? I assume the the connection to the turbo is justa flange with a fitting and the idiot light line must be an insert into the case with a banjo bolt? Any and all help appricated. I don't mind used but need to complete this aasembly so if you have the parts let me know or the correct part numbers thanks again
Ben
89 944,85.5 944
914-6werkshop.com
Old 02-10-2009, 10:37 AM
