at first the clutch pedal was real stiff so i changed the cable then the pedal bar snaped re welded week later snaped again.dropped motor replaced clutch bearing and backing plate replaced motor the clutch was real bad pulled motor found a crack in the fork causing the throw out bearing to bind on the pilot tube.the crack was hard to find due to the grease with a closer look at it there was rust half way in the crack so it was like that for a long time.hope this save's some one a lot of frustration.
Old 02-11-2009, 04:09 PM
nreed's Avatar
Since I've got mine apart I'm going to have a good look...thanks.
Norm '86 930
DTA P8Pro ECU - Synapse BOV - 60# Siemens inj - K27HF - Dual GHL - Kokeln IC - Elgin SC330 cams -
HRE 560R 8.5x18 ET25 11x18 ET0
https://flic.kr/p/nVgoAC
Old 02-11-2009, 04:26 PM
