juicersr's Avatar
Anyone ever had their clutch pedal snap in two?
Was in the middle of an awesome drive yesterday, when clutch pedal went to floor.
I carry a spare clutch cable for just such an emergency, but when i pulled on the clutch pedal, it came off and if found this under the floorboard
I know my clutch is stiff, but jeez, the car only had 80,000 and while i drive it hard, i dont abuse the clutch or anything. Would worn bushings resulting in off-angle forces with each clutch pedal motion cause this? Anyone else ever have this happen? If i get another stock pedal, will this happen again?
Also, is the clutch pedal/ cluster for 930's the same as for 911's? The pelican website seems to have parts specifically categorized for either, the 911, 911 and 930, or 930 alone, and there is no pedal or cluster rod for the 930. Thanks
'79 930/934 replica
80 RSR-look(Now in Sicily)
914/6 2.7 (Projekt 908/3)
1965 Karman Ghia-Class winner 2007 Carrera Panamericana/Ducati 900ss/GhezziBrian STW
D-Zug Produkte/D-Zug.com
Old 02-09-2009, 09:59 AM
mark houghton's Avatar
Holy crap Batman! Pretty strange place for metal fatigue. I bet you could get that welded up right-nicely, vs. buying a new pedal.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, stock everything else. The result of a massive Pelicanite good will fire recovery effort. Truely an open book, ready for the slippery slopes to modification.
Old 02-09-2009, 10:29 AM
beancounter
jwasbury's Avatar
Wow...
When I bought my car, the clutch was ultra stiff (which was a problem). Mechanic found that whoever did the prior clutch work failed to lube the throwout bearing IIRC. Anyway, my mech found that my clutch pedal was bent due to the excessive force that was required. I think he was able to cannibalize a pedal from parts in his boneyard. Maybe your car has had similar issues during its life.
Jacob
Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690
Past: 2009 997 Turbo Cab / 1979 930
Old 02-09-2009, 11:19 AM
juicersr's Avatar
Mark, do you think even a good weld would hold in this spot?
'79 930/934 replica
Old 02-09-2009, 11:31 AM
Twins are more fun!
JMA-RUF's Avatar
WOW... Talk about having a lead foot
James
Carrera TT
(3.3, Protomotive MAP ECU, EFI, GT2 EVO CAMs, Twin Plugged, Twin Turbo's)
Old 02-09-2009, 12:04 PM
Yeah, I think it would. A good weld is usually stronger than material being welded...or so they say.
As long as you've got it all apart, why not try welding her up? All it could do woud be to break again....and leave you stranded somewhere
Old 02-09-2009, 12:10 PM
juicersr's Avatar
LOL!
I looked at the pedal cluster on my SC and they pretty much look the same, except for the spring, which has the adjuster bolt on the 930 seen in the above pix. i have a line on a pedal cluster in good shape from an SC. Can anyone tell me if the SC pedal cluster is pretty much a 'plug and play' replacement for a 930 one? Considering all the wear and tear on my present cluster, though i would just replace it and rebuild the old one at my leisure.
'79 930/934 replica
Old 02-09-2009, 12:14 PM
poorsche930's Avatar
Same thing happened to me in like '94 or so in my Karmann Ghia. I just went to the backyard parts beetle I had at the time and robbed yet another part from it. Thats not unheard of. It's the pedal that sees the most movement.
Ryan
79 930..... among other fine German cars.
Old 02-09-2009, 02:51 PM
Turboo934's Avatar
Juicersr: They aren't the same,Turbo has its own part number and there are 3 shaft numbers. I had to replace them on Cristine a few years back,also had clutch peadle arm reinforced.
Old 02-09-2009, 04:05 PM
Wer bremst verliert
JohnJL's Avatar
You can have the welder "sandwich" it across the break if you want.
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 02-09-2009, 04:11 PM
9dreizig's Avatar
Location: Reno NV, Bay Area during most weeks,, Kids still in NH
Send a message via AIM to 9dreizig
I know my clutch is stiff, but jeez, , i dont abuse the clutch or anything.
Juicer, I just looked you up,, you're a registered clutch abuser in the state of N. Carolina. In fact it said you've even abused under aged clutches...
You'd better come clean dude!!
"Todd"
98 Tahoe ,2007 Saturn Vue
86 930 black and stock, 80 930 blue tracdog
91 Spec Miata (yeah I race a chick car)
"life"ll kill ya" Warren Zevon
Old 02-09-2009, 04:35 PM
juicersr's Avatar
Yeah, i suspected as much. Do u think it's ok to weld up, then reinforce with the sandwich plates? Any pix of how u 'reinforced' it? Cant seem to find new one listed on pelican
Anyone got a spare they want to sell?
Todd, LOL! Add it to the list of things i abuse!!
'79 930/934 replica
Old 02-09-2009, 04:41 PM
Turboo934's Avatar
Contact Dave at TRE. Don't use the old one it is metal fatigged . Start with a new or a good used one, gusset in the bends, replace rollpin with solid pin and replace clutch cable.It has to be for 79 Turbo, hole in shaft and arm set up the right geometry to pull the cable.
Old 02-09-2009, 05:58 PM
juicersr's Avatar
Thanks, will do.
'79 930/934 replica
Old 02-09-2009, 06:52 PM
Wer bremst verliert
JohnJL's Avatar
Looky here what I found...Its just dusty, it has about 10 track days on it after a complete rebuild with a kit from our host (receipt included.) I removed it only because I needed a 964 pedal cluster to accomodate my G50 conversion.
For Sale...
From a RoW 1983 SC, 60k miles on it.
Old 02-09-2009, 11:08 PM
Blackbird Pilot
Reaper930's Avatar
Damn dude was this in the 934?
Reaper | The Outlaw 930 Hotrod Gruppe Fünf Gruppen.com | The Baddest 934/5 Parts for the 911/930 D-Zug.us
Old 02-10-2009, 03:49 AM
juicersr's Avatar
Yeah, i think there is a racing pressure plate in her or someting, as it is one of those 'clutch is either in or out with no in between' deals. Obviously puts a helluva lot of stress on the clutch pedal. Just glad it didn't happen going cross country!
John, thanks but i think i have a line on a real turbo pedal cluster.
U guys with stiff clutches may want to check your pedals and maybe reinforce the bends per Turbo934's reccomendations. Better than being stuck.
'79 930/934 replica
Old 02-10-2009, 05:50 AM
I had the same thing happen to an '84 928 that I used to own. Got a replacement from 928 International.
Roger B.
Old 02-10-2009, 07:06 AM
you may have a crack in your clutch fork.i broke two pedals and made two engine drops before i found the problem.
Old 02-11-2009, 05:55 AM
nreed's Avatar
Can you please elaborate? I am intrigued but I don't understand how a crack in the clutch fork could cause a pedal arm to break. I recently snapped a clutch adjusting lever and am wondering if this is related. Thanks
Norm '86 930
DTA P8Pro ECU - Synapse BOV - 60# Siemens inj - K27HF - Dual GHL - Kokeln IC - Elgin SC330 cams -
HRE 560R 8.5x18 ET25 11x18 ET0
https://flic.kr/p/nVgoAC
Old 02-11-2009, 03:10 PM
