Registered Driver
Helmsy's Avatar
Ignition Timing
I want to check my timing and adjust (if necessary) so would like to know your procedures for checking timing (I have a Euro model).
In the manual I have it says to check timing (for a 930/66):
USA 1 +/- 2degs at idle (950rpm +/-) Vacuum Hose CONNECTED
Euro 2 +/- 2degs at idle (950rpm +/-) Vacuum Hose CONNECTED
And to adjust timing:
USA 26 +/- 1deg BTDC at 4000rpm Vacuum Hose DISCONNECTED
EURO 29 +/- 1deg BTDC at 4000rpm Vacuum Hose DISCONNECTED
I want to check my vacuum unit on the distributer is working properly so would like to know how you guys adjust your timing and if there are any hints and tips to getting it just right.
Ben
'85 930 - Black on Black
'95 993 Turbo - Silver
Old 02-09-2009, 03:33 PM
930turbo's Avatar
I have a '77 3.0. Mine is set @ idle vacuum retard connected, 5 degrees ATDC. I gain about 500 revs if I disconnect the vacuum hose indicating that it's working.
'77 930 turbo Garretson I/C 1 BAR spring, (2) '82 Triumph Bonneville Royal Wedding Edition
Past rides: '74 914 1.9 liter twin plugged track car, '83 928S, '87 924S, '75 911S w '78 ROW 3.0, '72 911T, '70 911T and various other insignificant domestic examples. Happiness is a grey tailpipe! Turbo lag......it's worth the wait!
Old 02-09-2009, 04:03 PM
Macht Schnell
les_garten's Avatar
I have an '85 Euro and I've always timed it like in RED here. I used that as a little insurance against detonation or a tank of bad Gazz. I don't much care what it is doing at Idle.
---Les Garten---85 930, Andial IC, GHL Headers, Fabspeed Dual, K-27 HF2, 3.4 JE Full Finned 7.5:1 CR, 964 CAM'd, Carerra 3.2 Manifold Cut/Flipped, Tec3r, Siemans 55#, GSF Fuel Rails, Clewett Crank Trigger, Clewett Cam Trigger,Dual Plugged, ARP Head Studs/Rod Bolts, Clewett Wires.Tial 46mm WG, Tial 50mm BOV, WEVO Shifter,934 Boost Gauge, Wideband EGO Sensor/Gauge, C2T Head Gaskets, '88 MB 300TE,BMW R100RT
Old 02-09-2009, 04:46 PM
OFF THE BOOST PIPE NOW...
A930Rocket's Avatar
I time my 87 at 4000 rpm.
Old 02-09-2009, 06:23 PM
Certified User
billjam's Avatar
This subject has me puzzled as well.
What timing is best to use if your motor isn't strictly US or Euro?
For example, I have an 86 US car (930/68) and I have deleted all the emissions control stuff (smog pump, O2 sensor, cat, etc.) and most of the cold start gizmos. It has SC cams and the dizzy with boost and vacuum ports.
In the Porsche manual (page 28-2b) it gives the following values:
Europe, ROW: 29 degrees before TDC at 4000 rpm (with vacuum disconnected)
USA: 10 +/- 2 degrees after TDC at 1000 rpm
California, Japan: 5 +/- 2 degrees after TDC at 1000 rpm
I have only recently put this engine back together after a major rebuild. I've played with a few settings and have settled on about 7 or 8 degrees ATDC at 1000 rpm and it seems to perform OK, but I don't know if this is the optimum.
Comments??
Can anyone explain why the Europe and ROW models are timed at 4000 rpm and not at idle?
Bill
1988 Carrera - 3.6 engine (with ITBs, COPs, MS3X) and a whole set of turbo body panels waiting in the attic.
Day job ... www.sspowdercoat.com.au
Memories: '68 912, '72 911T, '80 911SC, '84 911, '85 930, '86 930, '87 911
Old 02-09-2009, 11:41 PM
beepbeep's Avatar
Knock insurance. 930 engine is low C/R design that is unlikely to develop any boost at idle. Knock will occur where torque/VE is highest (around 4000 RPM).
That's why you want to be dead sure that advance is absolutely correct around 4000 RPM. If it's incorrect at idle, it will mess up emissions and do other stuff but it won't destroy the engine.
Thank you for your time,
Old 02-10-2009, 12:34 AM
good information !
Old 02-10-2009, 05:09 AM
930turbo's Avatar
You can check both. The total advance is important for detination as others have indicated, however, the idle setting is important for more than just emissions. Your intake vacuum at idle will vary significatly with initial timing. Intake vacuum has an influence on mixture via the control pressure regulator. For example, if your initial timing is too advanced, your vacuum will be above design and cause the mixture to go lean. It is best to have the timing correct on both ends of the curve to avoid compromising other things in your quest for the perfect tune.
Old 02-10-2009, 06:19 AM
beancounter
jwasbury's Avatar
FWIW, I tested my Control pressure regulator (WUR), and found that it does not respond to vacuum, only to boost. This is on my '79 US model.
Jacob
Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690
Past: 2009 997 Turbo Cab / 1979 930
Old 02-10-2009, 10:19 AM
Certified User
billjam's Avatar
I guess what all this really means is that if timing is set around 5 to 10 degrees after TDC at idle, it should also be about 29 degrees before TDC at 4000 rpm (with vacuum disconnected) if everything is working OK.
Correct?
Bill
Old 02-10-2009, 01:41 PM
Macht Schnell
les_garten's Avatar
Correct?
That ain't how I'd do it, and I wouldn't make that assumption. How about put your light on it, run it up to 4000, dial in your timing and you're done? What's wrong with doing it that way?
Old 02-10-2009, 02:02 PM
A930Rocket's Avatar
Thats how I do it.
...How about put your light on it, run it up to 4000, dial in your timing and you're done? What's wrong with doing it that way?
Old 02-10-2009, 02:17 PM
Registered Driver
Helmsy's Avatar
So if I run at 4000rpm disconnect vacuum and dial it in and then find that it isn't right at idle with vacuum connected then I can presume I have a faulty vacuum unit on the dizzy?
Ben
Old 02-10-2009, 02:32 PM
Macht Schnell
les_garten's Avatar
How about a distributor from another car/series? Anything is possible. These cars/parts are old and all portions of the distributor/ignition system should be inspected regularly for function. Advance springs, plate movements advance retard mechanisms, etc.
Old 02-10-2009, 02:52 PM
e170drvr's Avatar
Yes, Assuming you have the correct distributor connected properly set with the proper timing at 4000 rpm, also proper idle speed you should be in spec, otherwise your distributor probably needs some freshening.
87 930 Coupe Red, K27S, Kokeln IC, Rarlyl8 Headers system, Tial 46MM, .9 Bar. "Lola"
81 911SC Coupe Guards Red, Stock. "Zippy"
Old 02-10-2009, 03:46 PM
930turbo's Avatar
Your '79 has two ports, one vacuum and the other boost. The port on top is influenced by vacuum, the port at the base/front is boost. This allows the vacuum to lean slightly under light load and enrich slightly under boost.
Old 02-11-2009, 05:20 AM
930turbo's Avatar
The timing needs to be correct at both ends. You're checking two things during this tuning exercise, the total advance and the mechanical advance - or more importantly - mechanical retard @ idle. I just had an example this past weekend. An '83 SC that would not idle down below 2k when the total advance was set to spec. The distributor was at fault. It did not return all the way to initial due to sticky internals. I only had about 18 degrees of mechanical advance instead of 23.
Old 02-11-2009, 05:27 AM
Smart quod bastardus
fredmeister's Avatar
You should really check the entire function under vacuum and boost.
I found that idle timing of anything ATDC or even 0 degrees BTDC yields horrible off idle and low rpm performance. I could run faster than the car until 2500rpm.
It is important to limit advance to under 29 degrees at 4000rpm because detonation is the worst thing to happen to your engine. However, you don't want to get disappointed at low speeds if this forces a bad idle timing.
That being said, I time my 79 930 with the vacuum and boost hoses on my dizzy the following way.
Idle speed 950rpm timing to 4-6 degrees BTDC with vacuum hose connected. Remove the hose and see how far advanced it goes. This tells you how much vacuum retard the can is producing and check against specs from the workshop manual. If it don't work fix it.
Then I reconnect it and remove the boost hose and supply pressure to it with a small pressure hand pump and see how much it retards timing. This checks that the boost retard is working and how much you get.
Then run it up to 4000rpm and set the timing with the knowledge that under boost (when under load, not when checking it in the garage now) it will retard back that amount. This should be around 26-29 degrees max from what I see normally.
This gives me a good running car at low rpm around town and pulls hard when boosting.
I really wish some tuner experts would publish a timing chart that we could use for setting up our cars. Most of us here by now have modified the cars with k27 turbos and headers and a little more boost and I would like new data to go by that works.
I don;t want to destroy my engine until I find out the hard way. Plus who knows what distributor is on their 30 year old car, me being the 4th owner and being that Porsche supplied a few different versions over the years. California, US, ROW etc.
Which one has the ultimate advance curves and vacuum/boost retard features? lots of questions!
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, B&B intercooler, Snow Perf water/meth injection, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.7bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 02-11-2009, 07:01 AM
beancounter
jwasbury's Avatar
AFAIK, there is only one port that goes to the Manifold on my WUR (which is the correct p/n for a '79 US), the port on top is a vent which is plumbed to the airbox.
Jacob
Old 02-11-2009, 10:33 AM
e170drvr's Avatar
Fred, are you saying that you set your timing at 4000 rpm boost hose disconnected. so that it is advanced from your target value by the number of degrees of retard you were able to get with the hand pump?
Old 02-11-2009, 12:02 PM
