Twins are more fun!
JMA-RUF's Avatar
Porsche Crest Some teaser pics of my next project
Here are some of the bits I've collected for my next project
Still undecided hether I'll have these K16's modded to K16/24's, K16/16G's or mod the heat exchangers for GT28RS's.
Cheapest option would be K16/24 hybrids or K16/16G's...
James
Carrera TT
(3.3, Protomotive MAP ECU, EFI, GT2 EVO CAMs, Twin Plugged, Twin Turbo's)
Old 02-14-2009, 05:56 PM
Chain fence eating turbo
Nice!
Would love to hear some numbers once that thing is done...
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR P & C's, soon to be 993SS cams and GSXR 750 ITB's fed by 964 intake, Borg-Warner S366 turbo @ 1.4 bar, Treadstone full bay IC, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MegaSquirt 2 (v3.57 board) w/EDIS, Tramont wheels (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 02-14-2009, 06:02 PM
Twins are more fun!
JMA-RUF's Avatar
It'd be interesting!
The hybrid turbo's would have a flow capability of 550-700HP, depending on which route I take.
Boost will be limited to 1.25bar.
James
Carrera TT
Old 02-14-2009, 06:23 PM
torresmd's Avatar
That is going to be a fun project. Keep us updated with lots of pics please!
1986 930 Slant nose Black/black RUF
2004 996TT Gaurds red/Black EVO GT 660
2001 Ferrari 360 Spyder Rosso/Tan
1969 Carrera Widebody TurboKraft Custom (Mexico Blue)
2001 E39 M5 Imola/Black-red interior
Old 02-14-2009, 06:25 PM
Twins are more fun!
JMA-RUF's Avatar
Ooops! Here's the dual 50mm BOV's I'll be using:
James
Carrera TT
Old 02-14-2009, 07:10 PM
Twins are more fun!
JMA-RUF's Avatar
Oh, if I stick with the KKK "low-mount" hybrid solution, I'll probably go with one of these TurboWerx electric scavenge pumps for the oil drain. They're supposedly very reliable:
Write-up:
Proven, powerful, and quiet. Manufactured exclusively for TurboWerx, this custom engineered pump is an economical solution for returning hot oil from a turbocharger back to the engine sump. With its 1.75GPM (105GPH) scavenging capacity, it is powerful enough to scavenge oil from two turbos. It will self-prime/draw from over 5 vertical feet, and pump the oil as high as 20 vertical feet. The custom black anodized finned heatsink lowers operating temperature, further enhancing reliability.
This is the smallest and lightest scavenge pump available - fitting inside a 7.2" x 4.0" x 4.0" box. It weighs less than 5 pounds, and includes anti-vibration mounting hardware. It is specified to handle a maximum oil temperature of up to 300F, and the power consumption is 12 volts @ less than 3.5 amps. Pump inlet and outlet fittings are standard 3/8" NPT. Also suitable for other fluids, such as engine coolant, alcohol, and water.
Pump has higher temperature rating than Mocal and Tilton, and greater capacity. Pump has no internal pressure regulation - can be used with external bypass regulator (like an EFI fuel pressure regulator) to provide up to 100 psi pressure.
James
Carrera TT
Old 02-14-2009, 07:18 PM
Twins are more fun!
JMA-RUF's Avatar
... and this BELL IC looks the goods too... probably make it 28" x 12" x 3.5"
Depends on how much $$$ to fab up
James
Carrera TT
Old 02-14-2009, 08:17 PM
Me like track days
Craig 930 RS's Avatar
Wow, that's gonna be some work.
Very cool project! Keep us up to date, get to work! ;-)
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 02-14-2009, 09:01 PM
Twins are more fun!
JMA-RUF's Avatar
Thanks... It'll certainly be a fun project to get stuck into, that's for sure
James
Carrera TT
Old 02-14-2009, 09:26 PM
930gt-40r's Avatar
Very Nice!! wah wah we wah
Kris @ Tech9
86' 930/GT-40R Sold
94' Rustang GT daily (long gone)
2008 C6/Z51 Corvette
Old 02-15-2009, 07:23 AM
Twins are more fun!
JMA-RUF's Avatar
Thx - I think I'm going to get something like this made up
James
Carrera TT
Old 02-15-2009, 12:24 PM
James, please keep me informed to your scavange pump choice and how it works out, as I will also need to purchase one in the near future.
Thanks!
Jeremy C.
Why's he calling me meat? I'm the one driving a Porsche. (Bull Durham)
----Nothing is far away in this car!----
-1978 911 SC TURBO, Minerva Blue Targa 965 update.
-2008 550i M-Sport
Old 02-16-2009, 11:17 AM
Twins are more fun!
JMA-RUF's Avatar
The first pump pictured above is built to military specs, so I will probably go with that one for durability/reliability. Just need to decide on a good location to mount it, then "T" the oil drains from the turbo's into the inlet and pump the oil back into the oil drain sump plug/port. Pretty simple.
I'd prefer to gravity drain the oil into the sump plug, but it all depends on the location of the turbo's when mounted, relative to the sump plug. It just needs to flow downhill all the way.
James
Carrera TT
Old 02-16-2009, 12:27 PM
Why pump into the sump drain/port and not into the oil tank?
My first go at this was to gravity drain as well, but am thinking about using an electric scavange.
Jeremy C.
-2008 550i M-Sport
Old 02-16-2009, 12:31 PM
Twins are more fun!
JMA-RUF's Avatar
Yeah, pumping back into the oil tank is another solution of course
I currently drain into the sump drain port with my single turbo configuration. Works perfect.
James
Carrera TT
Old 02-16-2009, 12:34 PM
James do you have a pic of that? Did you have to drill/tap the case or did you mod the sump plate?
Jeremy C.
-2008 550i M-Sport
Old 02-16-2009, 12:38 PM
Twins are more fun!
JMA-RUF's Avatar
Sump plate? My car is a 3.2 Carerra - I just used a Male-to-Male union at the drain port.
James
Carrera TT
Old 02-16-2009, 12:48 PM
Yeah, please forgive me, I have a little bit of an older model.....
Jeremy C.
-2008 550i M-Sport
Old 02-16-2009, 12:58 PM
Twins are more fun!
JMA-RUF's Avatar
Contact Ben on this Forum... he has the bits for the gravity drain solution for the earlier cars with the sump plates. You won't need a scavenge pump.
James
Carrera TT
Old 02-16-2009, 01:23 PM
That is the reason why I questioned you choice to switch, but now I realize it is more due to the location of the turbos.
Ben too is switching to a scavange system (factory), so I will have to find out from him why he is making the switch.
Jeremy C.
-2008 550i M-Sport
Old 02-16-2009, 01:25 PM
