Wildcat96's Avatar
Fire Extinguisher
Just curious if anyone has a fire extinguisher mounted in their car? I was told it would be a good idea since my car is over 25 years old.....
Current / Previous Cars
1981 930 Turbo (Current)
2004 Audi A4 Quattro (Daily Driver)
2000 Boxster S (Sold)
Old 02-15-2009, 04:49 AM
Manassas, VA
lucittm's Avatar
I am looking for a (powered) passenger seat fire extinguisher bracket for my car also. I see that Rennline and Brey-Krause have them for sale. I am looking for a used one.
Mark
1991 964 Polar Silver Metallic Turbo Coupe
Old 02-15-2009, 05:07 AM
Forced Induction Junkie
WERK I's Avatar
Yep, since one of the underdash wires(non-fused) melted! No fire, just smoke. Fortunately, I was able to quickly pull over and turn off the ignition. If it had occurred during rush hour in Boston, it would have been a different story!
And no, I have not had the need to use it since it was installed.
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 02-15-2009, 05:36 AM
Manassas, VA
lucittm's Avatar
Dave,
Did you ever find out the cause of your high-temp wire?
Mark
Old 02-15-2009, 06:10 AM
WERK I's Avatar
Originally Posted by lucittm View Post
Dave,
Mark
Yes I did. It was the power to the power antenna. The wire grommet on the inner fender had worn through and over time the insulation of the wire worn off. It got pretty hot.....the wire started melting and fusing to the other wires laying next to it.
Dave
Old 02-15-2009, 06:15 AM
Manassas, VA
lucittm's Avatar
Wow, that is a great piece of trivia for those of us that have the power antenna. I am quite surprised that circuit is not fused.
Alright, everyone with power antennas run out to your car and check the wiring on the inner fender. It might save your car!
Mark
Old 02-15-2009, 06:56 AM
I have one in each of my collector / sports cars and in my tow vehicle - cheap insurance. I use BK brackets in the Porsches and really like them. I also like the BK quick release much better then the cheap QR's that come with the fire extinguishers.
Todd
Old 02-15-2009, 07:45 AM
Send a message via AIM to Chuck Jones
I have a Halon extinguisher in both cars....I lost my 99 C2 to a dash fire that started behind the radio while I was driving...very helpless feeling standing there on the curb watching your car burn up. I went with Halon....not the Haletron....because the Halon is much more efficient....in fact, so much more efficient that FAA requires aircraft to use the Halon...what does that tell you? Most of the vendors will steer you to the Haletron because of environmental issues.
1987 factory Slantnosed 930 Cabriolet/Guard's red
2002 Midnight Blue 996TT X50
1999 Iris Blue 996 (Dash fire burned and totalled 9/07)
+1 Halon is the only way to go. Chemical extinguishers can cause a real mess and damage.
Todd
Old 02-15-2009, 07:59 AM
Driver
Noah930's Avatar
I have a Brey-Krause mount that attaches to the passenger seat rails. The bottle (2.5 lb) is positioned under the passenger's calves. This came with the car when I bought it. Good thing is that the fire extinguisher is close at hand, even when I'm belted in. Some guy on the 911 Technical forum mounts his in the front trunk, which is probably as good as useless, IMO. Bad part about this BK mount is that it limits forward travel of the seat. Usually not a big deal, as I don't carry passengers. But if I did, that would hamper rear-seat access. I don't know if the newer BK mounts still have this problem, though.
I went with a handheld 2.5 lb Halotron fire extinguisher.
If you're super-serious about fire prevention or racing, you can install a 25-lb bottle with remote nozzles.
1990 Black 964 C2 Targa
Old 02-15-2009, 01:21 PM
Me like track days
Craig 930 RS's Avatar
Halon extinguisher on EBay - rental / bldg lease returns. Hell of a buy on a great unit -
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 02-15-2009, 03:58 PM
Large Member
krasuskyp's Avatar
I've got one mounted transversely on the tunnel hump just behind the the heater control, CVRPCA requires them to run DE's. I'd run outside and check the stats on it for you but it's in storage right now.
Ocassionally I'll corner so hard one of the two 'clips' will pop undone - that's my barometer it's been a "good day" heh heh.
Like it's been said - cheap insurance. Why not?
Paul... CT | '87 930 | '08 M3 6gang vert |
past:
| '07 S6 | '98 M3 vert | '01 M5 | '96 993 C2 cab | '05 S600 Sport - biturbo V12@Just Not Right 495rwhp / 612rwtq |
| '58 TR3A | '01 S8 | '95 S6 6gang | '88 M5 | '87 190E 2.3-16 |
Old 02-15-2009, 05:01 PM
Cowtown10's Avatar
Can you still buy Halon Extinguishers? I thought they were banned
Q
1991 RRC
1995 993 C2
2002 996TT
1984 930 Turbo (gone and missed)
Old 02-15-2009, 06:15 PM
cl8ton's Avatar
I just spent most of today installing my Extinguisher under the passenger seat.
I bought the Rennline (Power seat mounting kit) along with a 2.5 lbs MaxOut Extinguisher from our host.
Rennline makes high quality bolton's (not cheap, but good quality) IMO
Herz a shot
Rod...
2010 - 997 PDK, Black on Black, Daily driver.
1987 - 930 Grand Prix White, Not looking for crazy HP, just harmony!
Old 02-15-2009, 06:40 PM
WERK I's Avatar
Here's a Brey-Krause setup in my car.
Dave
Old 02-16-2009, 08:11 AM
Another option
Old 02-16-2009, 09:32 AM
Me like track days
I have mine - a 10lb - on the trans tunnel cover - totally out of the way FWTW
Old 02-16-2009, 09:45 AM
Large Member
krasuskyp's Avatar
Herz a shot
That's the unit and bracket I've got.
past:
Old 02-16-2009, 10:23 AM
cl8ton's Avatar
Nice choice Paul
I swear this Extinguisher mount added 10hp to my car!
Seriously, in the years I've owned my 930, it always made me nervous to not have one in the car after reading Chuck Jones story.
Rod...
Old 02-16-2009, 06:52 PM
Large Member
krasuskyp's Avatar
Hear DAT - dood...
...after watching me Westfalia go up ala Flambe Bus Sr. yr. entering my Catholic school lot (geeze do MAG engine blocks like to burnbabyburn... as the entire neighboring Technical HS student body began chanting)...
...I'll not purposely go sans again, nope.
8-)
(RIP Magic Bus)
Great mindz think alike Rod, on the exting's...
past:
Old 02-16-2009, 07:23 PM
