need help!! car acting up! asap!!!
hey i need a little advice if you guys can lend it, i was out tonight and i'm pulling into my fiance's neighborhood, and the tach starts going nuts bounces up and down goes all the way over and then dies out completely, and then when i get in the driveway i cut it off.. and it won't start for about 5 min... then all of a sudden it starts but the tach is still dead, and then i cut if off and try again and it does the same thing...
i can't really think of anything else tat was screwing up other than the boost characteristics were a little different than i had noticed before, it was surging more than normal at 4k and above, and partial throttle up high it would suddenly feel like i let off the throttle and slow down real bad but i was still in it a little, but under wot it pulled as hard as it ever does?? i'm so confused!!!
Old 02-19-2009, 04:46 PM
MEMBER # 930
waynesco1's Avatar
Vacume leak , hose popped off ? Gist a thought !
MEMBER # 930
Old 02-19-2009, 04:54 PM
Check the voltage regulator.
Make sure you are getting proper voltage from the alternator.
Old 02-19-2009, 05:03 PM
Crotchety Old Bastard
RarlyL8's Avatar
Ditto on the alternator. Check all your connections and output.
Old 02-19-2009, 05:05 PM
mark houghton's Avatar
Electrical is my vote, as in a bad ground or loose wire at the distributor or coil. The symptoms of the tach doing the mumbo-jumbo are tell-tale signs of bad connections. Your other running symptoms also reek of poor or intermittent spark.
I don't know that I can point you where to look first, but I bet a dozen other guys lurking around here can, so stay tuned!
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, stock everything else. The result of a massive Pelicanite good will fire recovery effort. Truely an open book, ready for the slippery slopes to modification.
Send a message via AIM to Chuck Jones
Same thing happened to me...turned out to be the alternator....then the battery because it wasn't being charged properly by the alternator...start with the alternator....but you might also check the charge levgel on your battery. Do you have a voltmeter? it should read at least 12.5....preferably 12.7
1987 factory Slantnosed 930 Cabriolet/Guard's red
2002 Midnight Blue 996TT X50
1999 Iris Blue 996 (Dash fire burned and totalled 9/07)
Old 02-19-2009, 05:15 PM
Ditto on the alternator,voltage regulater as the regulater attaches in the alternator. When it was mentioned to me I thought what the ####??, how could that be it. When I checked the voltage output all of a sudden it was vacillating way out of whack at over 16 and all those things started to happen, as yours does. Let sit awhile, restart, Ok for a short time then, Wallah it starts to get nutty. Tried the CD replacement first as that seemed the most logical, but the problem was more toward the beginning of the voltage food chain.
Anthony @ Voitureltd Bayside WI.
Old 02-19-2009, 06:13 PM
550SPYDER's Avatar
Alternator
___________________
Ryan
2001 996 Twin Turbo
1982 930
Old 02-20-2009, 06:57 AM
9dreizig's Avatar
Location: Reno NV, Bay Area during most weeks,, Kids still in NH
Send a message via AIM to 9dreizig
+1 on the alternator,, I suggest you charge your battery,, then hook it back up.. Start the engine and look at the voltage, running it shoudl be around 13.8 volts.. if the alternator is going bad will be significantly higher
"Todd"
98 Tahoe ,2007 Saturn Vue
86 930 black and stock, 80 930 blue tracdog
91 Spec Miata (yeah I race a chick car)
"life"ll kill ya" Warren Zevon
Old 02-20-2009, 07:53 AM
Wayah Road Warrior
Shadetree930's Avatar
I suspect the flames from your boost over-run melted your ..... wait for it ..... alternator!
http://www.youtube.com/watch?v=cZSN_6Alhis
But seriously ... its your alternator.
02 996tt White
87 930 GP White (Sold)
87 911 Targa Guards Red(Sold)
Old 02-20-2009, 08:37 AM
hahaha ... very funny!!
Well thanks everyone for the quick replies.. i got it back down to the shop, and waiting to find out if its the alternator or regulator... hopefully the battery is still good!! but thanks again everyone!!
Old 02-20-2009, 10:57 AM
