Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
M18x1.5 fitting for Bosch 044 fuel pump?
As part of my EFI upgrade I am installing a Bosch Motosport 044 rear fuel pump. The pump's inlet requires a Male M18x1.5 fitting and the Female fuel feed fitting from the chassis is an M16x1.5. Does anyone know where to source a Male to Male M18x1.5 to M16x1.5 fitting (steel or aluminum)? The fitting would look something like this:
Old 02-22-2009, 07:17 AM
What fuel fitting or hose configuration are other 044 owners using?
I bought one from Ebay when I was in the UK and supplied it with the pump, but the wrenches didn't like it and sourced their own to adapt to the factory fuel line IIRC.
Pretty much a standard, off-the-shelf fitting in Europe.
Failing that, you could knock one up out of hex bar stock in about 20 minutes with a lathe with a screwcutting attachment...
'77 S with '78 930 power and a few other things.
Old 02-22-2009, 10:10 AM
Not on this side of the pond
This is Plan B if I can't find one on the shelf in the next 48hrs.
Does anyone know of a good specialty Metric fitting supplier?
Old 02-22-2009, 10:48 AM
Take a look at http://www.j2precisionhose.com/products/Goodridge/Catalogue%20Pdf%27s/SECTION7.pdf. Especially at part #148-M16-M18 on p11 (metric adaptors, metric unequal male concave seat section).
Old 02-22-2009, 01:04 PM
BINGO I owe you a beer next when I visit Pacific Raceways
Old 02-22-2009, 03:09 PM
RPM Engine and Chassis
# Qty Category Item In Out Length Price Ext Cost
1 1 Fitting Fuel Pump #1 Inlet M18 Male Banjo 1/2" $20.00 $10.00
2.5 1 Fitting Fuel Feed Connector M16 Male AN 8 Male $6.39 $6.39
3 1 Fitting Fuel Pump #2 Inlet M18 Male AN 8 Male $6.75 $6.75
6 3 Fitting Fuel Block AN 8 Male 3/8 NPT Male $3.79 $11.37
7 3 Fitting Fuel Rail Weld Bung AN 8 Male Bung $4.78 $14.34
8 1 Fitting Fuel Rail 90 Weld On (Bulkhead) AN 8 Male AN 8 Male $9.69 $9.69
9 3 Fitting Fuel Pressure Regulator Feed AN 8 Male AN 6 O-Ring $5.59 $16.77
11 1 Fitting Fuel Return Line Connector M16 Male AN 8 Male $6.39 $6.39
3 Fitting Oil Breather Weld Bung & Valve Cover AN 6 Male Bung $4.24 $12.72
1 Fitting Bulkhead Nuts (Pair) AN 6 $2.52 $2.52
1 Fitting Oil Breather Bulkhead AN 8 $5.45 $5.45
1 Fitting Oil Breather Weld Bung - Oil Tank AN 12 Male Bung $6.99 $6.99
Old 02-25-2009, 06:49 PM
a bit late but...
just got a hold of some metric fittings from this company in ohio, anyone looking for some might give it a try. fair prices and reasonable delivery:
Malone Specialty Inc. | Metric Tubing, Tube Fittings, Hose and Couplings
not a great website-- i'd recommend calling them as they are actually quite helpful over the phone.
hope this helps,
sean
Old 01-25-2010, 07:48 AM
