purplehaze's Avatar
Damn, Tony, that's VERY clever.
Many thanks for posting!
I don't have the 3.8 tail with the openings, but plan to route the turbo intakes up for cooler air. I just didn't like the idea of flexy hose expanding and contracting each time.
Cheers -
Glenn
87' 930TT
Old 02-26-2009, 08:48 AM
Infidel
JBL930's Avatar
Originally Posted by VZ935 View Post
There is actually an aluminum piece that fits on top of the IC and mates up the the upening that looks like a huge NACA duct in the roof overlay/rear window... then vents out the bottom of the rear deck. The air basically gets pulled right though .
I see. I thought for a minute (from the rear view) it was like this
Jonathan.
87 930, 993 turbo engine, RS Tuning 520PS/515lbf-ft, Arrow Rods, ARP hardware, Solid lifters, G50-50, RS Flywheel, 890nm Sachs clutch, RSR coil overs all round, 993 C4 calipers front, 930 fronts on the rear, Ruf Speedlines.....
Old 540 BMW, XB12S Modified, for being a total hooligan
Old 02-27-2009, 08:45 AM
VZ935's Avatar
Send a message via AIM to VZ935
No that is a real 935 and a Andial customer motor from back in the day . They would never put the IC right over the top of the flat fan . Most of the engines had the IC toward the front of the car like in my K3 935 . (excuse the adj Motons... so what , I cheated)
A few were like my car including the Wayne Baker 934/935 that won the chapionship in 1983. Wayne explains this cofiguration here . He was running a single in GTO
http://www.waynebakerracing.com/images/934Champion/a_934_Champion.htm
Beautiful motor !
A bunch of old race cars
Old 02-27-2009, 09:15 AM
Blackbird Pilot
Reaper930's Avatar
Johnathan - please tell me you're gonig to fit that motor in your car
Van - "so what...I cheated" hahahaha, wasn't that the premise behind the 935? Simply beautiful!
Reaper | The Outlaw 930 Hotrod Gruppe Fünf Gruppen.com | The Baddest 934/5 Parts for the 911/930 D-Zug.us
Old 02-27-2009, 08:29 PM
Infidel
JBL930's Avatar
Can you imagine!! If money was no object then you could count on it!! Micke Svens has a 935 motor for sale, a genuine Andial motor, to own something like that would be a dream!
Van, you are a very lucky man, if you tell me you're also best mates with Hugh Hefner i'm going to jump off a bridge
Jonathan.
Old 02-28-2009, 01:58 AM
This set up worked fantastically on a great engine.Have gone different direction so all you see is for sale.
Just found ot replacement cost over $10000 . Anybody interested is welcome to make a reasonable offer-I am listening.
SOLD SOLD SOLD to soon reappear close by!!
Old 02-28-2009, 04:04 PM
Blackbird Pilot
Reaper930's Avatar
What size/type motor was it on prior? What was the designed output of the motor?
Old 02-28-2009, 08:18 PM
The were used with a 3.6 ---- 100mm pistons ,964 3.6 Crank, 3.2 case. Single turbo .Ran Motec and put out genuine big number ( very conservative dyno set up) Never more than 1.1 bar of boost.
Because of rules that the engine ran under(HP penalised) the focus was on torque- so it was set up that way. On the track it would beat CupCars , V-8's with alleged 650HP+ (I only mention that to make point about dyno numbers being questionable guide) It was very usable engine with no percievable lag.
I also have to sell-- the Cams, Pauter Rods,100mm pistons -all from the same engines( also a new set of 993 TT pistons-Cosworth Blanks)
Old 02-28-2009, 09:02 PM
Blackbird Pilot
Reaper930's Avatar
PM Sent Red9.
Old 03-01-2009, 01:04 AM
so what would be the best way to mount the throttle bodies, directly to the intercooler or have intakes that collect for each of three throttle bodies. I have notched that PMO now offers mfi, does anyone know anything about it? When I use the ITB setup on the 993 motor which ignition system would be the best to use, had thought about the kit from patrick racing and clewett engineering. I would be trying to do away with all of the computer controlled part of the 993 setup if possible.
Old 03-02-2009, 09:00 AM
My set up shown in photos above has been sold. Expect to see it back near here soon!!
I think this is close to the ultimate best system.
Old 03-06-2009, 10:15 PM
juicersr's Avatar
We just put a new motor in my 935 .. MFI of course because that's how Porsche rolled back in the 70-80's
Then I have Motec on this one but with a single throttle body works great . Cheaper, less moving parts than individual throttle bodies but of course leaves some power on the table. Motor did a dependable 600+ at 1.1 and never broke and looked like new inside after 60 hours of run time
Then on my buddy Bob's car we did Jenvees with Motec on an air motor but with water intercoolers
Van, do you posses any street legal turbo making less than 700hp that you could bring to NC for the summer mountain turbo run when Gabriel's car is done at Zuff? I know it would be tough for you to drive at legal speeds, but it would be for a good cause. Barring that, you gonna be running any of your steeds at Monterey?
'79 930/934 replica
80 RSR-look(Now in Sicily)
914/6 2.7 (Projekt 908/3)
1965 Karman Ghia-Class winner 2007 Carrera Panamericana/Ducati 900ss/GhezziBrian STW
D-Zug Produkte/D-Zug.com
Old 03-07-2009, 01:06 PM
juicersr's Avatar
Gabe, so THOSE TWM's. Ah yes, Looks like something big, round and very tasty will fit right between those puppies!
'79 930/934 replica
Old 03-07-2009, 01:15 PM
