Garrison's Avatar
Transmission help
After about 250 miles of driving the car I have now found some slop in the 2nd to 3rd shift. Seems a little longer then expected, and if shifting at all in the 3K+ RPM's the car lets out a slight crunch/wur.
I am by no means trying to throw it into gear, and have found if I press in the clutch, get off the gas, and let the car "coast" for a second I can get it into gear no problem...most likely everything has slowed down inside the box.
Am I right to assume that this is a bushing issue? (I know it is hard to diagnose over the web...) How do I go about looking at and replacing the bushings, etc. in the box? What does everyone recommend for bushings and so on?
Thanks for your help.
1996 Porsche 911
2013 BMW 335xi - Wifes car
2007 4Runner - 4x4 for Colorado snow
Past: 1988 Venetian Blue 911 Targa, 1983 Black 930, 1984 Black 911 Coupe
Old 02-26-2009, 11:11 AM
Garrison's Avatar
Great. Is this something that I can replace, or do I need to take it to a shop? Does the transmission need to come out? Are there aftermarket parts that I can put in place of factory?
Thanks again.
1996 Porsche 911
Old 02-26-2009, 12:02 PM
sudo apt-get purge 930
equality72521's Avatar
Whoaaa. Before you go yanking the engine and tranny you should at least LOOK at the bushings. It could very well be a simple repair. It might also need adjustment. Don't just jump off the deep end without seeing if there is any water in the pool.
--clutch-monkey
Old 02-26-2009, 12:08 PM
Garrison's Avatar
Agreed. I am not looking to drop anything at all if needed. Thanks.
1996 Porsche 911
Old 02-26-2009, 12:38 PM
mark houghton's Avatar
Let's see, Garrison, you've just recently taken possession of your beauty, and after puting on a few miles you find this shifting problem? Definitely listen to us-two Mark's and don't panic yet. It is an easy and relatively painless job to rebuild the shift linkage and/or coupler if that's the culprit, and also very simple to check and adjust the linkage for proper throw/alignment. And don't forget to make sure your clutch is properly adjusted. If the disc is dragging - and not completely releasing with the pedal all the way down - then of course it could result in difficult shifting. Go after the obvious first. All the information you would ever need is in this forum, if you don't have access to a shop manual...and even those are readily available as pdf documents on line.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, stock everything else. The result of a massive Pelicanite good will fire recovery effort. Truely an open book, ready for the slippery slopes to modification.
Old 02-26-2009, 05:24 PM
Smart quod bastardus
fredmeister's Avatar
Good advice so far to check everything concerning bushing condition and clutch adjustment. How is it going into first gear at a light or from a standstill and reverse. If the clutch is out of adjustment then these would be highly prevalent with difficulty getting into these gears because any clutch dragging shows up badly in these 2 gears.
Replacing the bushings is fairly easy and would be something to do anyway to make it like new again anyway. You might want to look into a short shift kit during this time too.
--fred
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, B&B intercooler, Snow Perf water/meth injection, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.7bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 02-27-2009, 05:24 AM
Garrison's Avatar
So going into first at stop lights isn't bad, but there are times that I need to let the clutch out, and put it back in and I can find first. Not that I didn't have first in the beginning, just didn't feel right.
The more I think about it, the more that the clutch dragging makes sense. When I push the clutch in for 2nd to 3rd and wait for that sec of two it goes in with no issues. When I push the clutch in and shift that is when it has issues. Alright... guess that is where I will begin.
Of course, looking at replacing the bushings still might be warranted.
1996 Porsche 911
Old 02-27-2009, 05:46 AM
You're on the right track but I would just go ahead an replace the bushings. I would bet my dog that they are worn. They are cheap and easy to replace. The original bushings in my 1979 were oval.
--clutch-monkey
Old 02-27-2009, 05:51 AM
Here is the kit for the shifter and shift coupler.
PEL-BUSHKIT1N
http://www.pelicanparts.com/catalog/shopcart/911M/POR_911M_Tshift_pg1.htm#item0
--clutch-monkey
Old 02-27-2009, 05:53 AM
Clutch adjustment is done underneath the car. You need to get the procedure from the spec manual or maybe find it searching these posts.
Make sure you have pedal free play and nothing limiting its travel inside the car too. Inspect the attachment points to the levers at the pedal end in the tunnel and at the tranny release arm because sometimes the clevis pin gets worn and causes binding.
If it is really bad going into reverse then likely it is clutch related because this gear is not synchronized making it difficult to get engaged even on a good car.
Old 02-27-2009, 05:55 AM
Garrison's Avatar
Thanks guys! I will order the bushing kit, and look at adjusting the clutch. I will report back and let you know...
1996 Porsche 911
Old 02-27-2009, 06:05 AM
One more thing to look at: Pull the inspection cover off (on the tunnel behind the front seats) and look at where the shift coupler attaches to the transmission shifting shaft. It's on a splined hub and is secured with an allen-headed screw. If that screw is loose, it will add slop. I had that problem at one time when I could not get into reverse. Cinched her down and the problem went away. And while in there, you can go through the shifting alignment procedure which is pretty basic (loosen the coupler at the squeeze bolt point and follow the procedure that should be found in the manual).
Old 02-27-2009, 08:48 AM
