sudo apt-get purge 930
equality72521's Avatar
Can't get front torsion bars out
They are stuck, both of them. Shouldn't they slide pretty easily? I have the a-arms out so I can put my polybronze bushings on and they won't budge. Any ideas?
--clutch-monkey
Old 02-28-2009, 10:42 AM
Also, I have two different a-arms. Someone replaced the pass side and it doesn't match the driver side. The driver side has thick spacers welded to the front mount. Is there a difference between the turbo a-arm and the 911 a-arm?
This one is original I suspect.
Not original:
--clutch-monkey
Old 02-28-2009, 11:08 AM
Happiest when Tinkering
gsmith660's Avatar
If those puppies have been in there a long time then it is a good chance a little bit of rust has jammed the t-bars in the housing I had that problem years ago when I replaced my bars, I am not sure about the a arms on the 911 verses the 930, have you checked the PET to see what the part numbers are.
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go!
76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3
76 Blazer also restored by me
Old 02-28-2009, 11:17 AM
I don't have PET
--clutch-monkey
Old 02-28-2009, 11:22 AM
gsmith660's Avatar
You can use the Pelican parts diagram that is actually a PET.
Old 02-28-2009, 11:32 AM
gsmith660's Avatar
2 different parts numbers but I dont know the differences in the a arms
Old 02-28-2009, 11:52 AM
I see a part number for a left and one for a right. Logic would say that if one side had the extra spacers then the other should too. I'm confused. I bought a spare set to rebuild in the meantime and that set doesn't have the thick spacers on either side. They might not be "turbo" a-arms if there is such a thing.
--clutch-monkey
Old 02-28-2009, 12:05 PM
gsmith660's Avatar
I ment thre is a 930 part # and a 911 part # right and left
Old 02-28-2009, 12:14 PM
I didn't see any 930 part number. Where did you find it?
--clutch-monkey
Old 02-28-2009, 12:28 PM
Here is what I found:
Left http://www.pelicanparts.com/cgi-bin/smart/more_info.cgi?pn=911-341-901-01-M100&catalog_description=A-Arm%2C%20Left%20front%2C%20911%20(1974-89)
Right:http://www.pelicanparts.com/cgi-bin/smart/more_info.cgi?pn=911-341-902-01-M100&catalog_description=A-Arm%2C%20Right%20front%2C%20911%20(1974-89)
Looks like the same part for everything from 1974 to 1989. Why is my driver side different though???
--clutch-monkey
Old 02-28-2009, 12:30 PM
Found this in PET on the Porsche website:
911 341 901 01 L SC
911 341 901 02 R SC
930 341 901 01 L Turbo
930 341 901 01 R Turbo
****. It looks like I bought SC a-arms to replace what I have.
--clutch-monkey
Old 02-28-2009, 12:44 PM
gsmith660's Avatar
go to this url
https://techinfo.porsche.com/techinfo/pdf/en/catalogues/E_911_83_KATALOG.pdf
go to Page 155, this the Porsche parts catalogue and it has 2 different part numbers for 911 and 930 this is contrary to the product info page and pelican needs to be made aware of this.
Old 02-28-2009, 12:46 PM
gsmith660's Avatar
Sorry you must have posted that while I was typing but that is it.
Old 02-28-2009, 12:47 PM
So now the question is can I use the SC a-arms I have? I bought these low friction mounts to go with the polybronze bushings for better alignment of both mounts.
http://www.elephantracing.com/suspension/mounts/911/911frontmounts.htm
--clutch-monkey
Old 02-28-2009, 12:59 PM
gsmith660's Avatar
I don't have an answer for that I would say take some measurements and see if they will work. There should be someone that can chime in here and answer this maybe call who you got the bushings from and see if they know.
Old 02-28-2009, 01:15 PM
Ok, Chuck Moreland has this to say: 911 & 930 A arms
--clutch-monkey
Old 02-28-2009, 05:04 PM
gsmith660's Avatar
Sounds like you are ok then.
Old 02-28-2009, 05:13 PM
Yeah, but if I can find someone that has a turbo front mount to match the one I have I'll be happy. Worst case I either fabricate some spacers or use them without. I'd like to make it right though. Thanks for the help with this.
--clutch-monkey
Old 02-28-2009, 05:17 PM
gsmith660's Avatar
No problem you might try Okla. for. for a used a arm then sell the sc a arms.
Old 02-28-2009, 05:22 PM
I got the old torsion bars out and they are in great shape thanks to a pointer from group911@aol.co. He told me the other end of the a-arm is just a plug and to drive the t-bar further in until it drives the plug out. Then drive it back the other way.
--clutch-monkey
Old 02-28-2009, 05:29 PM
