cycling has-been
bkreigsr's Avatar
77 930 3 pin or 6 pin?
simple question?
sorry.
I bought a spare CD unit from a 78 930 that is 6 pin without verifying whether mine is 3 pin or 6 pin.
help
thanks
Bill K
Old 03-05-2009, 03:11 AM
I think that the early 930's are 8 pin.
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 03-05-2009, 04:40 AM
OFF THE BOOST PIPE NOW...
A930Rocket's Avatar
Well, that was simple.
Originally Posted by bkreigsr View Post
simple question?
sorry.
help
thanks
Bill K
Old 03-05-2009, 07:23 AM
cycling has-been
bkreigsr's Avatar
cool, look for my 6 pin FS on the used parts forum*
I didn't know there was an 8 pin
thanks
Bill K
*after I pull the disconnect a bunch of pipes, tubes, relays, and wires to check the actual teminal
Old 03-05-2009, 08:03 AM
cycling has-been
bkreigsr's Avatar
jeez, I hope it's not the 8 pin - yipes
Bosch RSR 8 Pin CDI Ignition Box
Old 03-05-2009, 10:17 AM
mark houghton's Avatar
I'm so confused. Guess I'll go out and unplug mine and count them.
But wait.....I'm running with an MSD6AL, and it doesn't have any pins at all! Man, I'm screwed and didn't even know it.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, stock everything else. The result of a massive Pelicanite good will fire recovery effort. Truely an open book, ready for the slippery slopes to modification.
Old 03-05-2009, 10:32 AM
cycling has-been
bkreigsr's Avatar
you're confused ?!
I've been carrying this thing around in my track box as a spare and just now realized that it might not be the correct one.
Bill K
Old 03-05-2009, 10:42 AM
Bill,
If your 8 pin fails and you can't find another one, you can rewire your harness and use the 6 pin. Or go with MSD. If you are into originality then you are ***** out of luck.
Dean
Old 03-05-2009, 02:08 PM
cycling has-been
bkreigsr's Avatar
thanks all
I looked in the repair manual at the wiring diagram and then under the lid to confirm, and it is an 8 pin CDI.
They are really different looking then the 6 or 3 pin - huge
duh
after 31 years of faithful service from the oem unit, I guess I should be looking at the MSD as an alternative.
Bill K
Old 03-05-2009, 05:51 PM
