-   -   Advanced CIS Turbo Tuning Discussion Thread. Ultimate? (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/461279-advanced-cis-turbo-tuning-discussion-thread-ultimate.html)
911st 04-29-2009 07:23 PM
Agreed, I belive I noted that much earlyer in the thread.
cole930 04-29-2009 07:25 PM
Indeed you did !!!!!!
cole930 04-29-2009 07:36 PM
Dave,
Thanks for jumping in. There are only a couple of us that even remember these
D--- things. I bought this from Chris Fisher years ago in a box of stuff that came with my headers and Turbo. He originally saw it on a Mercedes CIS and started reproducing them for the 930's. I know Chris thought pretty highly of it but that's been so long ago I can't remember much. Any input about would be greatly appreciated. I decided to give it a try when I put the engine back end.
THANKS !!!
Cole
911st 04-29-2009 10:01 PM
From page one. ;)
Originally Posted by 911st (Post 4527318)
Look back at the forces in the factory digram above. The metering plate in the cone is basically a big valve. The more air flow or pressure through it the more it opens the vavle. At some point the valve goes past its intened range and spills over. That is when we stall.
All we are doing it keeping the mass up in the cone area so the air pressure will keep pushing it open.
It is more a trial and error. What would be interesting is to develop a way to make the windage adjustable.
With the increased windage may come quicker advancement of the MP at first, this would be countered by makeing the MP smaller in diamiter. That is what they did with the aftermarket above. It is taller and smaller in dianiter.
How about a wedge like this. It could even then be turned to effect the rate of advancment some with out having to redo the control pressures?
http://forums.pelicanparts.com/uploa...1236376821.jpg
WERK I 04-30-2009 04:49 PM
Originally Posted by cole930 (Post 4635768)
Dave,
THANKS !!!
Cole
Hi Cole,
Hope you're doing well.
I do remember when this cone was sold in one of the Porsche aftermarket parts suppliers (hint: California based) that compete with Pelican several years ago.
You mentioned to Steve about the metering plate mod.....did he happen to mention anything about having to adjust the fuel metering of control pressures?
It seems the cone "may" improve the full travel of the metering plate, but I wonder about cruising speeds where the cone may change the air flow characteristics at partial throttle.
911st 04-30-2009 05:11 PM
This may be a valid point.
If we keep the stock MP diameter and add volume to the top, it will advance further at all points.
If we add volume to the top of the MP and reduce its diameter (leave off the stock plate), it will slow back down the rate of advancement but should still continue past the old stall point.
Just a guess. :)
cole930 04-30-2009 07:47 PM
Dave & Keith,
In talking with Steve the Air mod will change afr's by it's self, more air more fuel, which will initially make it fat and blubbery at idle. We think the velocity cone will improve throttle response and probably accelerate the fuel curve some. Steve does adjust the system along with his mod but did not mention anything about adjusting for the velocity cone addition. The system pressure and control pressure are going to have to be dialed in but we are sure we will have more than enough fuel to support all the HP my mods can give us.
My intent was to make sure we have all the fuel we need without machining the control cylinder. The velocity cone will either do what we think it will or it won't. and it takes 5 min. to change it back to the stock metering plate if needed.
I think, from what we have seen initially, the DWUR will then provide the added flexability and control to put the right amount of fuel where you want it when you need it.
Dave thanks for asking about my health,. I actually feel the best I've felt in 5 years. It's amazing how much damage 6 months of Chemo will do to you, but I've been clean for 10 months. I'm not exactly pretty as I look like I was autopsyed but I'm as mean as ever and going 100 MPH with my hair on fire again. And it's sure great to be here with you guys.
Cole
fredmeister 05-01-2009 05:21 AM
Hey Cole,
Attitude is a big part of the recovery process.....keeping positive is a big plus, not only for yourself but those around you that care for you. It is almost as hard on them as it is on you.
Things like this make you appreciate life so much more.
Good luck to you.
fredmeister 05-01-2009 05:52 AM
Originally Posted by WERK-I (Post 4635721)
If I remember correctly, the added cone there to take advantage of the high velocity air passing over it. In theory, the cone adds spoiler effect to the metering plate, increasing downforce exerted on the plate to force it further in its travel. In theory......... :)
I never saw any scientific proof to support this theory, but it sounds good on paper.
btw, that cone is mounted properly. It only covers part of the metering plate.
The air flow through the opening is dependent on the cross-sectional area of the opening exposed between the metering plate and the machined cone in the housing at its specific height in time. Then as you can see if more air is required to flow thru the device, the metering plate must move down and create more cross-section for the air to flow thru. The angles on the machined cone are very critical as these determine the amount of vertical travel of the plate in relation to the amount of cross section that gets exposed. Basically it controls the rate of travel, a shallow angle will make the plate move more vertically per air flow and vice versa.
When the plate starts traveling to full travel it no longer moves vertically in the cone but as you can see at a great angle. The plate no longer controls the cross sectional area properly because of this and air is spilling out all over. This is the stalling phenomenon we are talking about.
What is really needed is a way to keep the plate perpendicular to the vertical axis so that the cross sectional area is kept directly proportional to the vertical travel of the metering plate and the pin inside the fuel distributor that meters the fuel. Kind of a 4 bar link.
The additional cone helps eliminate the spillage effect and also acts like a bell mouth to smooth air flow thru the cone at high velocity. Kind of like the air stacks on the Weber carbs which smooth flow of air thru the opening into the carbs.
In theory it looks like it should work, though the proper way to tell is to make no other changes but run it once with and without it installed and see what happens at full load and high rpm.
cole930 05-01-2009 02:02 PM
Mr. fred,
I agree. This is such a hoot to do, I feel like a cave man discovering the wheel. it's totally trial and error. Steve has the opinion that the factory air cleaner has a lot to do with optimal air distribution and flow pattern which is reflected in the metering plate operating correctly. He has suggested using the stock air cleaner
with extra holes cut into the bottom side of the element cover. May be something to that.
I've been wanting to ask you about how you like your K27S I've been considering going that route.
Cole
fredmeister 05-01-2009 03:33 PM
Originally Posted by cole930 (Post 4639145)
Mr. fred,
Cole
Cole,
Gotta love the k27S, nite and day from the k26 turbo. Boost comes in very early, like 2200rpm it starts coming in. All in by 2800 or 3000rpm I have to say. Plus it is very linear now in delivery. I also replaced the US heat exchangers with GSF/OBX headers and that probably has alot to do with the response as well. If your turbo is on the way out, mine had blown the seals on the intake side, then I say it is a no brainer.
Makes the car much easier to drive on track days without all the lag. Makes driving thru corners alot easier to modulate throttle, but still has the big punch once boost really kicks in at anything over 3400rpm to 6000rpm. I never really rev beyond 5800rpm or so because I don;t see the need to or risk throwing a rod. The rod bolts are the weak link on the 3.3liter 930 turbo they don;t like high revs.
I would also suggest a bigger intercooler, love my B&B set up.
cole930 05-01-2009 06:40 PM
Mr. Fred
Thanks for the reply that's exactly what I thought I would hear. I've been reading about the newer turbos and the K27S sounded like what I was looking for. I started with a K26 and went to a K27 7200, which was very nice. Now I have 934 short track headers and a K 28 11/11 from an old Brumos short track car. I'm like you as far as RPM is concerned when you run out of torque it's time to shift. I street drive only and have a short track 4 spd with 8:37 R&P and FA,HQ,QQ,WL gear set. I am looking for as little lag as possible and I'm not sure of what I'm going to get with the K28. Thanks for the help.
Cole
911st 05-02-2009 08:50 AM
Thought of one more way to cheaply add some more fuel up top.
By setting the normal CO adjustment to its max point or full rich, we allow the metering pin to advance further at the same point the metering plate stalls. Such an adjustment would thus give us more fuel up top.
This of course would make the motor run way to fat. Thus, by clipping the metering plate, we can get more air to flow around the MP at lower rpms to get the AFR/CO back in balance.
Originally Posted by 911st (Post 4535921)
How may ways can we deliver more fuel on a CIS system, let us count the ways:
Readjust the fuel head (IA or shim the head system pressure).
Increase flow of stock fuel head by adding windage to the top of the metering plate.
Increase flow of stock head by reprofiling and extending the cone that the metering plate rides in.
Increase flow of stock head by relocating the metering arm pivot (Steve W. Renn Sport mod).
Lower on boost control pressure using the Andial fueler or Digital WUR.
Lower on boost control pressure by using a 3.6 WUR or readjusting the stock WUR.
Us a fuel head from a V8 and plumb on or two of the extra injectors in as an additional injector (s).
Add an additional EFI fuel injector. (Not recommended unless driven at 100% duty cycle or uneven fuel distribution per cylinder.
911st 05-02-2009 08:57 AM
One more.
Add a boost modified fuel pressure regulator on the fuel head return line to bump system pressure under boost.
fredmeister 05-02-2009 12:19 PM
Originally Posted by cole930 (Post 4639507)
Mr. Fred
Cole
Check out the zork tube video. I made this zork and was a huge increase in throttle response and some power gain (seat of the pants) over the stock muffler I had. Not overly loud on highway because of wind noise but around town it is trouble.
http://www.youtube.com/watch?v=HmCQ_chad68
Also, you may be able to see the boost versus rpm on my tach in this video from Watkins Glen last summer. Look closely at the gages if you have good eyes....the video is not that clear.
http://www.youtube.com/watch?v=rPyqoSFcKCc
fred
patkeefe 05-03-2009 03:17 PM
Fuel Pressure
Originally Posted by 911st (Post 4640225)
One more.
Doesn't the control pressure regulator simply allow more fuel volume to the injectors via differentail pressure in the head? This is the impression I have been under. I actually found a clever little device at Summit Racing, which is basically a variable speed drive for the fuel pump which drives from engine rpm signal. I figured if one could get the WUR dialed in on lower pressure at lower RPM, there would be plenty of fuel then for high boost/RPM operation, and maybe get the mid range flat spot out.
I may have brough this up before, but that was a long time ago, so forgive any possible redundancy!
Pat
911st 05-03-2009 04:27 PM
Control pressure is what the WUR establishes to effect where the metering pin is positioned relative to air flow.
System pressure is the pressure in the head that is allowed to escape out through the injectors.
Differential pressure is the lowering of the pressure behind the diaphragm in the head that presses against the internal orifices that are the pathway to the injectors. As the metering pin advances, it increases this differential so more fuel is delivered.
At least I think that is how it works.
There is a pressure regulator built into the head just before where the excess fuel escapes to flow back to the tank is what determines the system pressure. Some shim this to raise the system pressure so more fuel is delivered. The problem with doing this is this increase comes in at all points including idle and cruse.
By adding another boost modified fuel pressure after the head that is progressive with increases in boost, we can keep our AFR's stock off boost but get more fuel on boost.
911st 05-05-2009 10:20 PM
The following is a good example of how AFR's are supposed to look like. The fuel system on a 930 is designed to support about 300hp. After that, things start to get interesting.
Originally Posted by RarlyL8 (Post 4164476)
I use the stock rebuilt WUR on my personal car. I dug through my files and found a baseline run for you. As you can see it does not dump fuel at boost onset. This WUR is not adjustable.
http://forums.pelicanparts.com/uploa...1220738021.jpg
Go beyond 300hp and the fuel metering plate moves past the metering cone and air starts to spill quickly around the metering plate and the plate starts to stall and things go lean quickly.
You can see this better in the following pictures.
:rolleyes: If we want to get these cars to work well w/o add ons at higher HP levels, this is the area that has to be improved upon. We need to extend the cone down further. Do this and there will be plenty of fuel for most.
Think of that cone like the map on an EFI system. This is the programming that determins our AFRs.
Manipulating control pressure can only do so much.
911st 09-21-2009 11:48 AM
The heart of our problem with getting enough fuel to support increased HP is the stock CIS metering system is designed to stall at an air flow rate equal to the expected maximum HP.
That is, if the motor is designed to make 300hp at 5500rpm the metering arm will advance down the cone until it gets to the targeted max HP air flow. Then the cone configuration is designed to start spilling air so the metering plate stalls at that point.
Otherwise the motor would continue to get more fuel with increased air flow that comes with more rpms past HP peak. The motor would not be able to use that extra air flow as efficiencies are falling off quickly.
When we modify a motor it flows a lot more air, the metering plate stalls at the 300hp mark, and we keep asking for air and go lean.
Understanding this is central to getting a near ideal AFR curve with a motor making more HP.
As a bandage we try lowering control pressure on boost (at the WUR or as the Andial fueler did) which dose move the stall point a bit, however, then lets the metering plate advance further than we need it to in the early stages of boost and we end up with a big fat spot on first boost.
Then we have to add another bandage so we put on an RPM clamp that delays enrichment or have to develop a programable WUR.
For someone that is skilled, it should be possible to put a CIS metering unit on a flow bench and by re-profiling the metering cone or adding volume to the top of the metering plate (see my wedge drawing earlier in this thread) we should be able to move the stall point to equal the expected air flow need to support our peak HP goal before it stalls. We would then also get proper AFR's.
We do not have much issue with getting more fuel to support HP up to 500fwhp, we just do not control it very well.
I trully belive we do not need excessive reduction in on boost control pressure, bost clamps, or D-WUR to achive our goals.
WinRice 09-21-2009 12:30 PM
So, your Mission, if you decide to accept it, is to fly to Germany, visit the Bosch headquarters and ask them what they're doing with all that 'old' CIS tooling, research papers, design software, etc, collecting dust in the corner. Then offer to take it off their hands and free up valuble space.
Once moved here to the U.S., use those resources to create a clean sheet CIS design with a target in the 500fwhp-600fwhp range. :D ;)
911st 09-21-2009 01:12 PM
Mission accepted! ;)
However there is probably an easer way. It would probably be more in the form of an adjustable metering plate. Or trial and error of fitting an air dam down into the Metering assembly bowl. How about if we trimmed the metering plate some so a dam might even be made to slip over the top and down into the pot of the end where the metering plate so quickly opens up an dumps air off the end.
Though most are not varying much from each other as to the upper target builds these days with similar cams, IC's, turbos, and boost as limited by fuel quality so one sise might fit all. It would just come wht a little richness past HP peak to those that come up lower than expected. Much better than going to lean.
This also might open up up a strategy of using a vacuum enrichment WUR like the 3.0 turbos did instead of boost enrichment for better throttle response and less of that off idle lean spot that comes with a 3.3CIS motor.
JFairman 09-21-2009 01:32 PM
I think the biggest motor that ever got CIS was the Mercedes 450 SEL 6.9
Maybe there's something about that version thats different from the 4.5, 5.0, and 5.6 liter Mercedes V8's on CIS that was different.
WinRice 09-21-2009 01:56 PM
Just kidding around:D
There is no doubt in my mind that a CIS system could be re-designed and/or re-engineered to function well on a 500 fwhp-600 fwhp engine, even 800. But would it be worth the time, effort and money?
It would be fun, though!
911st 09-21-2009 03:31 PM
J,
There might be some ideas there. There fuel heads might have potential. Especially for an extreme build if one uses the two extra injector lines for extra fuel as additional injectors.
The modified throttle plate idea thats pictured several posts back supposedly came form a 6.9 MBZ or AMG I hear.
mark houghton 10-19-2009 10:28 AM
I thought I would move 911st's comments found on a different post over to this advanced CIS tuning thread. On the topic of boost vs. vacuum sensing WUR's:
How about donating your old WUR for study. Maybe someone could document how to convert to a vac-sensing WUR from the boost sensing. Lee Rice used to do this on his "Rice Fueler" WUR years ago.
The boost sensing WUR's reduce the resistance of the metering plate to movement upon acceleration. Doing this would increase pre-boost response if set up right.
Of course this is not a good fit with a set up on a car that is set up to dump to much fuel on boost. However, I believe a heavily modified 930 could be set up to still work with this by getting the control pressures right for the fuel head used.
This would not only reduce resistance at the metering plate but could reduce the lean surge off idle that is typical with CIS.
That seems to be Porsches intent with the 3.0T's. Emissions were probably part of the reason for the boost triggered unit on the 3.3T's.
If the earlier WUR's do indeed respond to vacuum, then wouldn't it have to be an all-or-nothing response...since vacuum doesn't progressively build like boost does, and rather is either there or not? I can understand the proposed benefit of getting an early onset of metering plate deflection by the WUR reducing control pressures in response to vacuum, which should happen as soon as your foot hits the gas pedal. But would that assure enough enrichment after boost starts to build?
911st 10-19-2009 11:39 AM
My understanding is both the Vac-Sensing 3.0 and the Boost-Sensing 3.3 Turbo WUR's are all or nothing. There is not really a progressive nature to either when triggered. (However I am sure someone could engineer a progressive system which would have benifit.)
With CIS the AFR's are not really liner. They are more of a curve.
We basically have a Cruse-AFR curve. And,
We have an Acceleration-AFR Curve.
Then there is a quick 'transition between the two fuel curves.
I do not believe that if you could plot the two curves they would have a consistent delta between them. The control pressure can determine the slope of each curve. The the metering cone determines the rate of change of the curve at different air flow rates.
The typical 3.3T boost-trigered enrichment CIS goes lean with first accel then stabilized pulls back to near 14.5/1 untill enrichment is effected depending on one's CO setting.
My thought is we should be able to set up with a vaccum-trigered WUR where we are at around 14.7 at idle and get an instant 13/1 AFR with acceleration just off ideal which is where a 911 motor makes its most normaly asperated torque.
If we continued to accelerate we could set up the fuel curve so it would continue to become richer until it is gets into the low 11's at Torque Peak (apx 5krpm)which is where we are most sensitive to detonation. After that it might start to lean some depending on how much fuel and air one can flow.
The other place we are concerned about our AFR will be on curse. If cruse is under 3000rpm we should be able to stay at above 14/1 with out much issue and at still meet our other goals.
Here is a crude drawing of what we might be working toward.
http://forums.pelicanparts.com/uploa...1255977429.jpg
mark houghton 10-19-2009 03:37 PM
We need to be able to modify a WUR to do both...vacuum as well as boost enrichment. Use a boost enrichment delay solenoid in conjunction with vacuum enrichment modification (if possible) to get what you're trying to achieve. Or, the infamous "cone head" on the metering plate.
I have a perfectly good '87 WUR that I could play with in this regard, but really don't want to risk trashing it.
e170drvr 10-19-2009 04:28 PM
OK, kinda shootin from the hip here. If I am reading correctly we still have some travel left in the arm for the metering plate. I have a lot to learn about cis, but the issue as I understand it, is that our metering plate as a result of it's tilt has exceded it's critical angle of attack and stalls. Maybe this has already been considered, but what if we modified the plate so that it would pivot, and then use a small rod attached to the center of the plate that is inserted into a sleeve attached to the crossbar. This would allow movement throughout the entire operating range, with the plate remaining flat thus never stalling. Just a thought.
Eric
911st 10-19-2009 05:46 PM
Mark,
I do not think we can combine approaches. To do the Vac-loss enrichment with an extended HP car we would have to fix the over rich issue in some other manner than using the rpm delay clamp. This takes us back to curing the metering plate stalling issue or just tuning around it with the WUR.
When we did the first of what bacame the HF head we found it went way to rich everywhere but near the end of the rpm range. With my suggestion we tryed running it without any lowering of the CP on boost. It looked like a near perfect AFR's and it even extended our fueling some up top. But again, the metering plate would start to stall and we would not get all the increase we needed nor that was available. That is when I came up with using an rpm clamp to delay enrichment. With this, the vac sensing is not viable.
Just a side note, Volvo makes a "delay-pill" that goes into the vac line to the WUR that might be somthing to look at as an easyer way to delay on boost enrichment. I do not know anything other than it exists.
One could use an Andial fueler but delay it with the rpm switch combined with the vac sensing WUR. This would give one two stages of control pressure lowering. The first with vac-loss at the WUR and the second lowering of CP under boost and later in the rpm range.
I do not think any of these add one's are required if we can match the fuel head to the WUR settings, and fix the metering cone so we do not get stalling after about 300hp worth if air flow or so.
Years ago when we were doing this, some were finding good low end response improvement with the Rice Fueler that was vac sensing. It provided both vac-loss enriching off idle and combined this with a lower on boost CP for more fuel on boost. Back then there was not the HF head to exadurate the issue. However, it was hit or miss depending on how the motor was set up. For many the early lowering of CP let the turbo spool up faster. For some, it might go fat earlyer. Just depended on the set up.
Because of this and my experance with agressively lowering the CP with my own electronic WUR I know there is a performance gain to be had.
Eric,
You are on the right track. It would probably be easer to add volume to the top of the plate (see picture in post 108). Another thought is to reset the fuel head to flow say 15% more fuel (HF) and then maybe bend up the end of the metering plate. If one hit the sweet spot, the metering plate might advance 15% slower at first as more air is escaping around it to offset the added richness coming from the HF head but then the bent lip would stay further up in the cone so it would not stall as soon. If the factory did it it would just re-profile the cone and come up with a matching WUR that has the right control pressures.
mark houghton 10-19-2009 07:59 PM
Originally Posted by 911st (Post 4961805)
One could use an Andial fueler but delay it with the rpm switch combined with the vac sensing WUR. This would give one two stages of control pressure lowering. The first with vac-loss at the WUR and the second lowering of CP under boost and later in the rpm range. .
That was a suggestion I floated some time ago if you recall, but in combination with an rpm window switch and vaccum sensing relay, and a stock boost reactive WUR. Set the window switch to activate and deactivate at something like 1500/3500 rpms and tied in series with a vacuum switch. Operation of the Andial frequency valve would occur immediately once vacuum is seen AND the pre-set lower rpm limit is met, and would deactivate once 3500 (or whatever programmed) rpm was reached....just in time for the WUR to start enriching as boost builds (all dependent upon the turbo being used and how fast it spools). Net-net would be a controlled stepped enrichment through the entire power band.
It just so happens I still have my Andial enricher still installed but no longer using since my Leask WUR provides all the control I need. May just have to scab together the rest of the parts and test out the theory.
911st 10-19-2009 08:16 PM
Could just put an activation switch in place of the hobs switch but in the cab and push it any time you want to activate the Andial. You could hit it off idle for lowered control pressure if you want or on top of the BL at high rpm to see if there is any benifit to lowering the CP any more up top.
964 T #304 10-20-2009 05:54 AM
Or you could use a digital wur and lower the control press. @ any rmp you want
911st 10-20-2009 07:41 AM
That is the best way.
I has probramable control over control pressure on my C2T 7 years ago and it greatly helped off idle response. Probably the most noticable improvement along with increasing my AFR potental by abut 1 point in the upper RPM's.
Still, if I get to do a third CIS turbo I will do it without add ons and a vac-sensing WUR conversion.
Erland Cox 10-22-2009 10:12 PM
I did some research and found out that the metering plate hat was used in the Mercedes 190 2.5-16. This was a 4 cylinder high performance car that was a homologation special for DTM, the German touring car championship. The earlier model 2.3-16 which did not have the hat on the metering plate had shorter stroke, a little milder cams, more compression ratio and a thinner exhaust header. The bigger engine has 202 hp instead of 185 and that is comparable to the increase in capacity. Maybe Mercedes where running close to the limit of plate stall with 185hp already so they invented this trick to be able to continue to use the same injection? There was a special evolution model of this car with 30hp more and maybe it was only this one that had the plate mod? I will check on that. I will check if this car uses an 6 cylinder unit which it should. I also know someone who has an 450 SEL 6.9 and I will ask him if this mod was used on this older car. Below a link to some info:
http://en.wikipedia.org/wiki/Mercedes-Benz_W201
Erland.
911st 10-23-2009 07:24 AM
Welcome Erland.
I bought a 190E 2.3 in 1985 and lusted for the 16v.
"The roadgoing version of the engine was reconfigured with reduced inlet and exhaust port sizes, different camshaft profiles, no dry sump configuration and Bosch K-jetronic replacing the specialised Kugelfischer fuel injection."
Are you saying any of the models has a metering plate with the added profile or are you saying they might be a place to look.
AMG at one time developed a black box that used a frequency valve to effect Control Pressure for more fuel on some there cars. Andial borrowed this and it became the Andial Fueler.
I borrowed the plumbing part and made up my own controler so I could program my AFR's at all load and rpm points. Bassically an early version of the D-WUR.
It makes sense that a manufacture would tune the CIS system so the metering plate would stall at peak HP. Otherwise the motor would go rich after peak HP where efficiencies are falling off and no additional fuel is needed.
Erland Cox 10-23-2009 09:46 AM
They are very nice cars. My friend bought one in southern Germany and I drove it home to Sweden. I wouldn't mind having one myself. According to my source all the 2.5-16:s have them. He also says that the W124 300E-24 also has this mod. The 6.9 doesn't. He was going to check his manuals and also measure the plate diameter on the 2.5-16. It has a 4 cylinder fuel head but I guess that the metering plate is the 6 cylinder size. Does the Porsche have a V8 unit with a 110mm metering plate? I will try to take a look at the metering plate of a 300E-24 and see how big it is. My friend thinks he has one somewhere and probably Mercedes still sells them. They still stock Pankle titanium rods for the Evo versions of the 2.5-16. The first racing 2.3-16:s had K-jet, i believe up to 87 and electronic injection after that. They had around 270 hp with k-jet. I think Porsches metering plate is bigger than Mercedes though so this is only a link to where the special plates where used. I have a 911 SC and on that I used Splash Zone A-788 epoxy to reshape the inlet to the metering plate. No before and after dyno tests where done though. I am working on a Volvo 240 turbo with K-basic right now so I read through the thread to get some ideas. I need to double the stock output and I want to keep the K-jet. The plate hat and the probable added travel is something that I am going to try. Erland.
cole930 10-23-2009 11:28 AM
Welcome Erland,
I'm the guy who has the velocity cone. It came off an earlier MB V8 ie, 6.5 or
6.9 I find it very interesting they show back up in later models which brings us
full circle to our original quest. Why were they used and what advantage, if
any , were they. We all would be very interested in any information the might
be out there.
Cole
911st 10-23-2009 11:35 AM
Erland,
I saw a digram of a Volvo once that had something called a Delay Valve and it is plumbed in to the vac line going to the Control Pressure Regulator.
Do you know any thing about it?
I wonder if it might help some of here that want to delay there on boost enrichment with WUR's that go to fat at first because they have lowered CP's dialed. This could possibly be an option to using a MSD & solenoid valve as a boost clamp.
http://forums.pelicanparts.com/uploa...1256322772.jpg
911st 10-23-2009 11:38 AM
Now that I look at the WUR I am wondering if it is a two stage setup. It has two source tubes plumbed into it with one hooked to the Delay Valve. Could be two different levels of boost or one boost and one loss of vac (acceleration).
Erland Cox 10-23-2009 02:40 PM
I haven't seen that on a Volvo myself but SAAB had two different systems with electrical control valves. The oldest one had a non adjustable WUR that was bypassed above 130 km/h or by a throttle switch at 2/3:s throttle by an external line and a solenoid. From 1980 there was an adjustable WUR with a control valve on the pressure line from the manifold.
On my Volvo I have done several tests to see what happens with the pressure and my WUR will not lower control pressure below 2,5 bars with boost. Full boost CP lowering was in at 0.5 bar but this must be adjustable by changing the bottom spring in the WUR. I will try to rise my CP above the 3.5 bars I have now to see if The WUR still lowers to 2,5 bar or if CP can only be lowered 1 bar by the boost diaphragm. It would be nice if there was a manual from Bosch for the old K-basic racing systems. I can scan and post the drawings from the SAAB workshop manual as soon as I have somebody here to help me with it. I am not a computer expert and that might just be the reason I like mechanical things like k-jet. My Mercedes friend brought a leak tester yesterday. It pressurizes the intake system with smoke from heated baby oil. It showed that my aluminum and plastic intercooler was leaking a lot. A leak check is very important before you start adjusting. Erland.
