930s rule the wasteland
h20cooled7's Avatar
Send a message via AIM to h20cooled7
Innovate AFR
What AFRs are you guys running at idle with mods (K27 ,full bay intercoolers,euro fuel heads)Just trying to fine tune and was curious how fat to adjust.
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 03-09-2009, 03:38 PM
After the next project
x98boardwell's Avatar
Also have Innovate digital
I would say it is the same all over....
Ideal settings:
1) Idle/cruise when warm: mid 14's
2) WOT: 11.9-12.0
This should be a consensus. The trouble with CIS is that you will be able to dial in the #1 but when you are in WOT you will go to 10.1 or 9.9. If you go to lean, then you will always be too lean unless you are in WOT. I tend to go normal on #1 knowing that I will be pig rich at WOT because I know it is safer. Can anybody with CIS chime in here if I'm wrong or can adjust?
If you are running EFI then you will have multiple options and ranges that you prefer no matter what RPM you are in.
Hope this helps, best of luck.
Bryan
Old 03-09-2009, 04:59 PM
h20cooled7's Avatar
Thanks Bryan!
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 03-09-2009, 05:07 PM
