Jiu Jitsu Grappler
Rodsrsr's Avatar
ICV question
I'm sure someone will know the answer to this rookie question: I've been using the stock throttle body boot for my low boost 3.2 application. I've just replaced the old worn out boot with a new silicone replacement. The problem is that the new piece doesn't have the hole for the nipple to hook up the ICV. There are a few vacuum points that I can tap into, but they are all below the throttle plate. Will this effect how the idle control valve operates? If so are there any other ideas? Ive seen a bunch of 3.2 turbos here in the past with the silicone boot, where are they hooking up the ICV?
Jiu Jitsu Grappler
Know Gi / No Gi
1976 Turbo Coupe 3.2
2009 Carerra S 997.2 (SOLD)
Old 03-10-2009, 05:13 PM
David's Avatar
The ICV needs to bypass air across the TB, so the inlet port has to be above it and usually has to be 1/2" or larger. Can you weld a bung onto your intercooler?
2014 Cayman S
2011 Cayenne Turbo
Old 03-11-2009, 11:07 AM
Twins are more fun!
JMA-RUF's Avatar
ATPTurbo sells these, which MIGHT be suitable
James
Carrera TT
(3.3, Protomotive MAP ECU, EFI, GT2 EVO CAMs, Twin Plugged, Twin Turbo's)
Old 03-11-2009, 02:21 PM
Jiu Jitsu Grappler
Rodsrsr's Avatar
Thanks guys. That answered my question. 125shifter; Im not running an intercooler (low boost 7psi) but the piece that JMA posted is perfect.
Jiu Jitsu Grappler
Know Gi / No Gi
Old 03-11-2009, 04:20 PM
Twins are more fun!
JMA-RUF's Avatar
You may just need to figure out how to couple it to your TB and AFM
James
Carrera TT
Old 03-11-2009, 04:37 PM
