Smart quod bastardus
fredmeister's Avatar
how to adjust VDO boost gage
I have a VDO boost gage in the clock hole location that reads a little low. It is teed into the brake booster line as per standard practice.
I verified this against my LM-1 gage that is picking up a sigmal off the recirculating valve housing or after the outlet of the intercooler above the throttle plate.
When the boost on LM-1 says 13.5psi the VDO gage reads 0.75 bar on the needle or about 10.8psi. Only explanation I have for the large discrepency is pressure loss across the wide open throttle or VDO gage inaccuracy.
My question does anyone know how to rest the needle on the VDO gage by indexing it a little to match the LM-1 reading which I assume is dead nuts?
I don't want to send it away to Hollywood Speedo to get charged for this....want to do it myself.
Second question is how much pressure drop should be expected before and after throttle plate considering the source of my signals to each gage as described above?
Fred
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, B&B intercooler, Snow Perf water/meth injection, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.7bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 03-11-2009, 12:28 PM
Mr. Fred,
Can't help with the reset question. I did have the same problem with taping into the brake booster, not quite that much differential though. I ended tying into the waste gate boost line and it worked great.
Also if you have a telltale on your gauge they sometimes loosen up and the needle slips.
Cole
Cole - 80 930 "The Old Sled"
Mods: TurboKraft Custom IC, 934 Headers, GSX 61, Zork, Port Work, SC Cams, Air Mod Fuel Dist Relocated, Water Meth Injection, BL WUR, MSD 6530, Greddy EBC, Synapse Bov, Short 2nd & 3rd with 8:37 R&P, Wevo Shifter, Coupling, and Mounts, MTX-L SSI-4, Big Brakes, Rebel Coilovers, Bilstein Sports.
Old 03-11-2009, 01:29 PM
DP935 member
kycarguy 935's Avatar
Fred there is a reset key made that fits in the center piece of the guage. I don't have one for mine but need to find one.
Porsche Slantnose M505 M506 group on Facebook.
https://www.facebook.com/groups/719995181372494/
Old 03-11-2009, 05:23 PM
KY,
Do a search here I saw a post some time back that told who has them.
Cole
Old 03-11-2009, 06:33 PM
