LinkBack Thread Tools Rating: Thread Rating: 6 votes, 5.00 average.
Turboo934's Avatar
George: If you get up to Taos we could go to Eske's for a brew. Would love to see your Turbo,PM me.This week end the motor will be out, see how bad. Thanks for all your support.:
Old 03-18-2009, 08:21 PM
Turboo934's Avatar
Who does cleaning of oil coolers I have three that will need cleaning. Are there any aircraft motor builders in Denver?
Old 03-23-2009, 07:48 PM
resident samsquamch
sand_man's Avatar
Not in Denver, but lots of folks have used these guys (Pacific Oil Cooler):
http://www.oilcoolers.com/
-jeff
Old 03-24-2009, 05:32 AM
Turboo934's Avatar
Thanks Sand_man. Is this the same company that was in Elsagundo by LAX?
Old 03-25-2009, 06:31 AM
purplehaze's Avatar
What Jeff said. Good call on using Pacific Oil Coolers. They did my tank as well when I spun a bearing. It came back like new
Glenn
Glenn
87' 930TT
Old 03-25-2009, 07:15 AM
Turboo934's Avatar
Well yesterday we had a foot of snow.
My 3 year heeler, Shakira had 7 pup's 10 weeks ago. Snow was pretty much gone by the end of the day. Back to Cristine,
[img]http://forums.pelicanparts.com/uploads14/P10002431238251422.jpg[/img
She sure had pretty colored pipe.Lots to do.
Old 03-28-2009, 07:57 AM
Blackbird Pilot
Reaper930's Avatar
SCHWEEEEEEEEEEETness - gawd do I love that Pinup.
Reaper | The Outlaw 930 Hotrod Gruppe Fünf Gruppen.com | The Baddest 934/5 Parts for the 911/930 D-Zug.us
Old 03-28-2009, 08:20 AM
Turboo934's Avatar
Well the motor she is out , I opened the valve covers hoping to see a loose rocker arm. No such luck, so it's a bearing.
Old 04-07-2009, 06:52 PM
cl8ton's Avatar
I still say this is the most advanced engine jacking stand on earth for a 930!
I used an ATV jack with plywood, not conducive to accessing exhaust stuff with engine out
Ps…are they real or fake? Cristine’s that is!
Rod...
2010 - 997 PDK, Black on Black, Daily driver.
1987 - 930 Grand Prix White, Not looking for crazy HP, just harmony!
Old 04-07-2009, 08:11 PM
Turboo934's Avatar
They 'd be real . I made it from mostly old leftover Porsche parts and a old motor yoke. You can balance the motor & trans and it will lift the motor to the stand.
Old 04-07-2009, 08:34 PM
cl8ton's Avatar
You gotta post specs on that engine lifting marvel sometimes before Nov Turboo934!
I suspect my engine will come out for a new clutch by then
Good luck on your rebuild!
Rod...
Old 04-07-2009, 08:58 PM
"O Gruppe 13"
IDGAF27's Avatar
Send a message via Skype™ to IDGAF27
Hi there, have unrelated question. I do remember someone asking some' similar, but I curious about Cristine's butt. I mean hips. I mean flares.
As I understand they are bolt on, right? Do you have to cut fender lip to attach 'em? Those goes on top of a regular flare? Can you enlighten bit on this topic. I have a wheels I like to use, but mines 930 'hips" ain't wide enough. Rubber sticking approx 1 to 1.5 inches on each side.
Thanks.
Gytis
86 930 Kokeln IC and Turbo; Zork;SC cams,Port&Polished
68 911T/R "Special wish program Nr.184*** car"
67 911 2.0L, 901, Webbers,Matching #'s
68 912 original to the bone
Old 04-10-2009, 01:38 PM
Turboo934's Avatar
Yes you have to cut the fender to apply the 934 flairs.Not recomened for the faint of heart.
Old 04-10-2009, 03:57 PM
"O Gruppe 13"
IDGAF27's Avatar
Cutting is no problem.
Problem is I don't want to cut.
Thanks for answer.
Will fallow Cristines surgery as well will be exploring my options....
Gytis
Old 04-10-2009, 06:16 PM
Turboo934's Avatar
Looked inside cam towers and intakes all looks good.I'll be splitting the case this weekend, hope the crank isn't damaged too bad. Anyone have a 3.0 crank just in case?
Notice how I swapped 2&5 on the fuel head like the 934's did.
All look like this
Old 04-10-2009, 08:58 PM
Manassas, VA
lucittm's Avatar
OK, I'll bite. What does swapping 2 & 5 on the fuel head do for you?
Thanks,
Mark
1991 964 Polar Silver Metallic Turbo Coupe
Old 04-12-2009, 05:23 PM
Turboo934's Avatar
Update on Cristine's surgery, split the case yesterday. #1 rod bearing is bad and some wear on mains. I will have to check paper work to see if crank was turned before, I know the case was line bored. So I'm looking for a 3.0 turbo crank or a Carrera 3.0, big plus having the doc's on your car. Seems to be alot of contamination inside, when I removed the through bolts the oil smelled burnt. Motor never showed signs of overheating , I don't get it? I will post the pixs when I get them down loaded off my camera.
Old 04-17-2009, 02:05 AM
georgeinhere's Avatar
R,
Every time that I think about going to Taos, it decides to snow...wtf? Haven't had a second to take the car out and been working long hours. I scored some speedline Ruf wheels (8/10s) for my car as well as an exhaust...we need to get together!
Cheers,
G.
Old 04-17-2009, 07:31 AM
Turboo934's Avatar
Yeah I know woke up this morning 6" of snow four hours later and it's still snowing.Bechin on the rims lot easier to find tires for than my 15's.What kind exhaust did you get? I hope something loud, love Turbo's on the pipe.
Old 04-17-2009, 08:38 AM
juicersr's Avatar
Che, why was the case line bored and crank turned on the prior rebuild? I thought both the 3.0 turbo/carrera cases and cranks were some of the most robust made. Does line boring once preclude doing it again? I hope u dont need a case...i recently looked around for either a 3 turbo or carrera case for a future project a while back, and had a tough time locating one.
'79 930/934 replica
80 RSR-look(Now in Sicily)
914/6 2.7 (Projekt 908/3)
1965 Karman Ghia-Class winner 2007 Carrera Panamericana/Ducati 900ss/GhezziBrian STW
D-Zug Produkte/D-Zug.com
Old 04-17-2009, 07:31 PM
