LinkBack Thread Tools Rating: Thread Rating: 6 votes, 5.00 average.
Turboo934's Avatar
Well my parts made it to Taos by way of Boston. Talk about the long way home,four times these parts have been cross country.Tomorrow the parts will go to the machine shop,to balance them with the crank.Thank the TURBOO GODS!!!!Yes Justin I'll take pic's of doing the rear bearings and mono ball inserts. I may get to drive Cristine yet this Summer, I need a Turbo fix
Old 06-15-2009, 09:58 PM
Turboo934's Avatar
where can I find an intercooler like this?
Old 06-17-2009, 02:22 PM
Find a wrecked 959 Sport.
Or, have Bell make one for you. Like I noted earlier, they have 6" thick cores. Those look close to the dimensions I guessed at.
Old 06-17-2009, 02:57 PM
Turboo934's Avatar
Find out in the 11th hour that the machine shop hasn't located any galley plugs. DAMM !! I can't believe that it took me 4 hours to track them down. The cam towers #90110537900 on the shelf at Stooddards. mains galley plugs are a 964# got that info from old Porsche machinist. Stoddard is the only ones to bother with us vintage car owners, besides PP but some of Wayne's salesmen are as dumb as a bag of rocks about cars.
Old 06-26-2009, 02:21 PM
guys over at EBS have a lot of vintage stuff as well, always been able to get me what I need in short order...
82 930 Pearl White 3.3 964 cams, K27 HF, Kokeln, fuel enriched, IA fuel head mod, wur mod, crankfire, 2X plug, Aase worked heads. 1bar, GHL, zork, 23/33 bars, low, loud
Old 06-26-2009, 02:36 PM
Turboo934's Avatar
Not much to report other than got the galley plugs. I get to pick up motor next week from the machine shop.
Old 07-10-2009, 07:17 PM
Turboo934's Avatar
Oh and that wet spot on the front grill was a broken oil cooler
Old 07-10-2009, 07:22 PM
Turboo934's Avatar
Just ordered some Pirelli's for Cristine, 345\35\15s & 225\50\15s. I tried these once before, with old rubber bushing and torsion bars. With all the suspension changes they'll work alot better. The Yokies have been great but there aren't any, and the backs aren't quit wide enough.
Old 07-11-2009, 10:50 AM
juicersr's Avatar
Nice to hear things are coming along.
You are going to be amazed at the difference. I just replaced all the bushings in my SC, along with raised front RSR front spindles, new torsions, bearings... she is like a new car.
Are you going to stay with stock torsions, go larger, or going to put some cool stuff in like 935 spring plates and coilovers? After tracking my turbo at Turbopalooza, i now realize that i have more motor than suspension, and need to seriously upgrade a lot of stuff. I have a suspicion you are going to be in the same situation with the new power from your motor. U may want to think about upgrading suspension components now while she's apart and and you are twiddling your thumbs waiting for the motor.
'79 930/934 replica
80 RSR-look(Now in Sicily)
914/6 2.7 (Projekt 908/3)
1965 Karman Ghia-Class winner 2007 Carrera Panamericana/Ducati 900ss/GhezziBrian STW
D-Zug Produkte/D-Zug.com
Old 07-11-2009, 11:15 AM
Turboo934's Avatar
Shes had coil-overs on her for 3 years and poly-bronze bushings. Just doing rear mono balls& bearings. I've never ran the Pirell's with the up-graded suspension. She's been on Yokies since then.
Old 07-11-2009, 02:29 PM
Blackbird Pilot
Reaper930's Avatar
A man after my own heart post pics when you mount them up, there's nothing cooler than huge rear rubber.
Glad to hear the coils are working for you well - I know that on mine they definately helped a ton with some of the common handling issues i've read about.
Reaper | The Outlaw 930 Hotrod Gruppe Fünf Gruppen.com | The Baddest 934/5 Parts for the 911/930 D-Zug.us
Old 07-11-2009, 08:53 PM
Turboo934's Avatar
Rt 66
Cristine before suspension change with Pirell's Ended up with to much neg. camber and toe out squat under power. Wore the tires out in 5,000 miles.
Old 07-12-2009, 10:17 AM
Turboo934's Avatar
Pirellis showed up yesterday, date codes are from 08. Damm forgot how wide the rears were,she'll be sure footed now,they're 2.5 inches wider than the Yokies.
Old 07-16-2009, 07:36 PM
Blackbird Pilot
Reaper930's Avatar
Pics of the tires bro! PLEAAAAAAAAAAAAAAASE! You know how I have to have my wide tire fix for the day
Old 07-16-2009, 08:38 PM
Turboo934's Avatar
Tires
Old 07-18-2009, 12:24 PM
Blackbird Pilot
Reaper930's Avatar
You Sir, are the freakin' man! Wide tire goodness - god those look sooooo good
Old 07-18-2009, 08:39 PM
juicersr's Avatar
Nice!
Anyone know what the max recommended rim width is for the 345's?
'79 930/934 replica
Old 07-18-2009, 09:07 PM
Blackbird Pilot
Reaper930's Avatar
Tire rack suggests 13.5" max rim width for these.
That's the same recommendation on mine for the Corsa's I put on there and on my 13.5" wide rim I could probably go to a 14" without much fitment issue. I'd assume the same for these but we'd have to see when the get installed on the rims.
Old 07-18-2009, 10:45 PM
juicersr's Avatar
Sweet. I now have a street compound tire for my 914/6 which has 14" rears.
'79 930/934 replica
Old 07-19-2009, 03:10 AM
OFF THE BOOST PIPE NOW...
A930Rocket's Avatar
That is awesome!
Old 07-19-2009, 07:17 PM
