LinkBack Thread Tools Rating: Thread Rating: 6 votes, 5.00 average.
newb.
eimkeith's Avatar
Originally Posted by Turboo934 View Post
The intercooler is set on a angle ,it goes from the bottom of extension to top of fender. Basicly the fender is a tunnel . Works quiet well.
It's bigger than the oil tank. It was in the car when I bought it, but I replumbed it .
When are you going to pull that intercooler out and geive me dimensions?!? (or did I miss that part of the thread?)
Come'on, I'm dying to go 934 and need to do it with the early tail....
keith
'75 RS/RSR-look | '67 Kaiser M715 | '73 CB750 | '70 TD250B
r gruppe #436
zuffenhaus: products|eurowerks
Old 07-22-2009, 03:59 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #101 (permalink)
Why not just put a Carrera rubber on the 930 tail.
Old 07-22-2009, 04:09 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #102 (permalink)
newb.
eimkeith's Avatar
not the same, not the same....
keith
r gruppe #436
Old 07-22-2009, 05:08 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #103 (permalink)
Turboo934's Avatar
Ta da !!!!!
I finely got the motor back from the machine shop. Now for the build, which will take less time than getting partsSoon as I get over this bout with kidney stones and infection oh the pain! I will be in Cristine's hanger building the motor. Pic's to follow soon
Old 07-29-2009, 08:25 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #104 (permalink)
Blackbird Pilot
Reaper930's Avatar
Get well soon buddy best wishes and prayers your way.
Reaper | The Outlaw 930 Hotrod Gruppe Fünf Gruppen.com | The Baddest 934/5 Parts for the 911/930 D-Zug.us
Old 07-29-2009, 11:26 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #105 (permalink)
Would someone trace this Idiots spam home address so I can go burn his house down.
Cole
Cole - 80 930 "The Old Sled"
Mods: TurboKraft Custom IC, 934 Headers, GSX 61, Zork, Port Work, SC Cams, Air Mod Fuel Dist Relocated, Water Meth Injection, BL WUR, MSD 6530, Greddy EBC, Synapse Bov, Short 2nd & 3rd with 8:37 R&P, Wevo Shifter, Coupling, and Mounts, MTX-L SSI-4, Big Brakes, Rebel Coilovers, Bilstein Sports.
Old 07-31-2009, 01:08 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #106 (permalink)
Turboo934's Avatar
Cole: I have the same K28 11/11 as you how hard does it hit compared to a K27 7006.
Old 07-31-2009, 01:22 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #107 (permalink)
newb.
eimkeith's Avatar
Turboo934, is that intercooler larger than a 996TT cooler?
keith
r gruppe #436
Old 08-02-2009, 09:02 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #108 (permalink)
Turboo934's Avatar
Keith: The inter-cooler on Cristine is 20X11X3, that is with two tanks 3X2.5X11. So the core is 15X11X3, it's still larger than a 3.3s inter-cooler.
Old 08-02-2009, 04:12 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #109 (permalink)
newb.
eimkeith's Avatar
sweet, thanks.
keith
r gruppe #436
Old 08-02-2009, 06:21 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #110 (permalink)
Turboo934's Avatar
Con Rods
Started inspecting my parts, I have a concern on the rods. When they were balanced they shaved the squared shoulder where the cap & rod meet on 4 of them. I'm concerned about this , I'm using Raceware rod bolts. All pic's I've seen in my books show not shaving this area.Do I have a problem or is this ok?I will post pic's later. They also removed numbers on the pistons that matched the cylinders. What do I do here?
Old 08-05-2009, 06:01 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #111 (permalink)
Turboo934's Avatar
Con Rods
Here are some Pic's
Old 08-05-2009, 06:24 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #112 (permalink)
OFF THE BOOST PIPE NOW...
A930Rocket's Avatar
I think you are OK. That's where mine were lightened as well. No really other place to lighten them I think.
Were the piston/cylinder numbers written in ink or etched? Are they new, used or re-conditioned?They may have etched the numbers somewhere else.
Old 08-05-2009, 09:47 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #113 (permalink)
Turboo934's Avatar
Henry Schmidt says I'll be fine sense I'm reringing them. Just being over concerned,don't want anything to happen to my baby again.Thanks A930Rocket
Old 08-05-2009, 02:09 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #114 (permalink)
A930Rocket's Avatar
Check the gap between the new rings and the ring lands. New rings can grab the cylinder walls and wobble in the ring grooves, eventually killing the pistons.
That's what I've read anyway...
Old 08-05-2009, 05:08 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #115 (permalink)
Turboo934's Avatar
Parts are parts
Ring gaps are in spec., was one of the first thing I checked . Cristines motor only had 40K miles on it, so the P&Cs are in good shape. Thanks for your advice A930Rocket. Got my other set of SC cams yesterday, as mine had a scored lobe on the left cam. They're repairable ,but I'll do that later or sell them off , they are an SC grind from Web Cam also. Everything is here now to start the buildLet the build begin !!!
Old 08-07-2009, 02:07 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #116 (permalink)
Turboo934's Avatar
Old 08-13-2009, 10:42 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #117 (permalink)
Turboo934's Avatar
Thumbs up
In the beginning there were PARTS
.jpg[/img]
The crankshaft that came out of Cristine #91610201600 was replaced with the same.
Old 08-24-2009, 01:35 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #118 (permalink)
onboost's Avatar
Crank looks nice.. any mods done to it?
RGruppe #180
Old 08-25-2009, 05:54 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #119 (permalink)
Turboo934's Avatar
No just polished & balanced,this is the same crank as used in the 934 it has a 916 part # not a 911 #.
Old 08-26-2009, 11:38 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #120 (permalink)
