89 930.
Benny771's Avatar
1978 intercooler?
Hi,
Just wondering what a 1978 intercooler will fit(its on a 78 now)? Or are they all the same?
I have a 1989...
Thx
Old 03-16-2009, 06:23 AM
After the next project
x98boardwell's Avatar
Answer
The IC from a 78 turbo should be able to fit all the way up to an 89 and be a bolt on application. I'm guessing that it is an aftermarket IC that you are looking to buy... the reason why I ask is that you would not want to put a stock one one since it would be the same as yours.
Best of luck. Provide pics when you get them.
Bryan
Old 03-16-2009, 08:19 AM
Depends on the manufacturer if it's aftermarket and a short neck intercooler that needs the intermediate diverter manifold to fit.
As far as I know all the origonal 930 intercoolers were the same.
The only change in that area of intercooled 930's was the mounting angle position of the auxiliary air slide valve that bypasses some air around the throttle body during cold starts.
Because of that the air hose fitting on some intercoolers like the Garretson halfbay is at a little different angle for different year applications so the hose going to the aux air valve would fit better.
The difference in the hose fitting angle is small and you can cut out sections of preshaped generic heater hose from a watercooled car to make a good fit with different intercoolers and aux air bypass valves and make it look like an origonal fit, if your inclined.
Some people don't like the high idle during cold starts, or the extra weight and clutter of the parts and remove that stuff and plug the fittings.
Old 03-16-2009, 09:43 AM
89 930.
Benny771's Avatar
Thank-you all,
Im awaiting pic's from seller.
Old 03-16-2009, 01:32 PM
