jopo911's Avatar
Brake Squeal
1986 930 new Mintex brake pads all around. Problem: Horrible screaching/howling primarily from right front passenger side last foot or so before totally stopped. No noise until almost stopped, barely moving. I tried new "anti squeal" stick on pads on all brakes, did nothing. Car stops on a dime, does not pull, etc. Anybody have any ideas what else to check? It is driving me crazy and is very embarrassing
Joe
1986 Black on black 930
Kokeln IC/ 1 bar spring/European Fuel Head
GHL Exhaust Dual Exhaust, Wevo shifter and coupler
935 Front Air Dam, Forgeline wheels
Old 03-16-2009, 12:08 PM
OFF THE BOOST PIPE NOW...
A930Rocket's Avatar
Try another set of pads.
Old 03-16-2009, 05:35 PM
BReyes's Avatar
When you install your new pads, do you chamfer the edges to help prevent?
Regards,
Bernard
Old 03-17-2009, 07:21 AM
jopo911's Avatar
No, I did not. Just angle them a little?
Joe
Old 03-17-2009, 09:38 AM
BReyes's Avatar
It may be another issue. Chamfer will work probably short term (I bought a set of front brake pads for 87 NA and they are sitting on top of tool box as they still have plenty of pad left and doing the rear a while back has been fine).
Yes you can sand the pad at 45 deg with say an 80 grit, removing only a small amount from the edges. Hope this works and rotors are good. Maybe you have given up on your pads?
Bernard
Old 03-19-2009, 09:31 AM
jopo911's Avatar
Thanks for the reply. I have not given up on the pads, since I have them in the rear also, and they are fine. I am going to try your suggestions, as well as closely examine callipers, etc.
Joe
Old 03-19-2009, 01:17 PM
