Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
proffighter's Avatar
Help 930 brake confusion
Does anybody know for sure, wich brake circuit is for front/ rear? In the service manual the push rod circuit is for rear calipers, in the parts catalogue the lines of the push rod guide to the front calipers
Which one is now the right one? IMHO it's the push rod circuit for rear in cause of the smaller stroke (14mm)
I checked some threads/ pics about, and there you'll find both versions
So who knows the correct lining?
Roland
930 Turbo '81 Too many modifications to list
Old 03-20-2009, 06:37 AM
Question
Still no help
Maybe a pic of a MC and wich line goes where...
Roland
Old 11-30-2009, 01:45 AM
nreed's Avatar
I'm confused as to what you mean by "push rod".
Norm '86 930
DTA P8Pro ECU - Synapse BOV - 60# Siemens inj - K27HF - Dual GHL - Kokeln IC - Elgin SC330 cams -
HRE 560R 8.5x18 ET25 11x18 ET0
https://flic.kr/p/nVgoAC
Old 11-30-2009, 05:30 AM
Push rod means rod who pushes piston, in this case pushed by pedal through booster.
Second circuit is floating one, forced by fluid/ pressure of first circuit
BTW its called push rod in the service manual
Roland
Old 11-30-2009, 11:50 AM
