89 930.
Howdy:
Ive got a couple of friends with different opinions. One friend is a tire guy and the other is a Racer/mech (for years). One said that the pressure should be near the max that is marked on the tire. Other said follow the sticker on the car. Which is right? They both had good points to justify there answers. This is for street use. What do you guys set at? Thx. 1989 930 |
It depends on many many factors, such as: wheel size, tire size, tire compound, suspension mods... at the end of the day w/o details I'd say 30~32 up front and 36~38 on the rear.
I run 32 up front and 42 in the rear with stock wheels and tires on my '87. Car sticker and the manual says 29 up front and 44 in the back, I think. From what I've heard, the 44 is more designed for extended high speed triple digit kind of stuff. Lower is most likely OK at "normal" speeds (but wait, "normal" for a 930 may not be below triple digits). Hmmmm.....I've confused myself again.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, stock everything else. The result of a massive Pelicanite good will fire recovery effort. Truely an open book, ready for the slippery slopes to modification. |
89 930.
For 30 in the front, what are the chances of a belt shifting? That is what my tire guy said to watch for.
I guess i could keep an eye on the temp's? |
What????? belt shifting????? Temps????? with 30#. Watch your tire guy...
Driver
Additionally, if you change wheel or tire sizes, then you may need to adjust your tire pressures accordingly. If you're on the track, and you're going to be hard-core about it, then you'll adjust your tire pressures depending on what readings you're getting from your pyrometer and your handling preferences. I would not go along with the "whatever's printed on the side of the tire" recommendation. That's ridiculous.
1987 Venetian Blue (looks like grey) 930 Coupe 1990 Black 964 C2 Targa |
Forced Induction Junkie
Keep in mind tire pressures and suspension settings given by the factory were intended to give the 930's as much understeer possible at higher speeds. This would give the lesser experienced drivers warning that they approaching the cars limits and they should lift. A car with as much oversteer the 930 can have, this would spell disaster for the inexperienced.
Search the threads on Pelican for people who track or autocross their cars and want the most neutral handling they can find. The factors are near limit-less...... ![]()
Dave '85 930 Factory Special Wishes Flachbau Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P |
Driver
The understeer swaping to oversteer in a fraction of a sec is the greatest fun of driving our cars... NO electronics contol - YES!!
Depends if you want tight or loose in corners. I personally like push/tight in the hills of Tucson.
EPS NO-Bama country
AMG V8 SL55 Mercedes, 993 C2, 86' Carrera 3.6 hot rod, Purple 1998 993 that didn't make the cut, 3 very old 930s, A/Fuel Dragster CH3NO2 (R.I.P.), Blown Alcohol TAD, AA/AA, 360 Maxim wingless, Cummins Turbo Diesel. Amateur Welder, Painter and sculptor sort of. - |
+1000000000000000......... Because this is EXACTLY what I do!
Bill |
I autocrossed today and tried different pressures to get some thoughts on what works the best in my 930.
Based on recommendations from a couple of old 911/930 guys, I tried 29/44; 29/38; 27/34 and 27/32. The final setup was the best as far as traction and adhesion to the road. I HATED 29/44 - felt like I had NO traction in the corners when things heated up. I actually spun out on a corner that I have been through dozens of times before - at a relatively slow speed. Once I got below 29/38 everything fell into place. the final steup was the best, but 27/34 was also pretty good. Btw, i'm running the sumi's on stock fuchs. It may be that as tire tech has changed, the original recommendations are no longer all that applicable.
1989 930 black/black 50.5kmi stock past 1987 911 targa black/black 1988 911 coupe black/black 1982 911SC coupe black/black |
Large Member
This is helpful Jobah, thanks for sharing. I assume you set / measured each setting cold (well, as cold as you can get them between autox runs)? Or are they purely hot settings? Just curious.
I wonder if these autox settings might work for a track event? now WHERE oh WHERE did you find an autox on a Thurs. afternoon? Kudos.
Paul... CT | '87 930 | '08 M3 6gang vert | past: | '07 S6 | '98 M3 vert | '01 M5 | '96 993 C2 cab | '05 S600 Sport - biturbo V12@Just Not Right 495rwhp / 612rwtq | | '58 TR3A | '01 S8 | '95 S6 6gang | '88 M5 | '87 190E 2.3-16 | |
For my Toyo R888s 295/30-18 and 235/40-18 on the track (hot)
Front 32 Rear 37 Steady and excellent grip for 15+ straight laps ![]() |
Registered Abuser
There is thread in the track fourm on this. A lot depends on what you are running the car setup, weight few other factors. R compounds or street tires? track or street. Michelen Pilot Sport Cups have worked well for me 28 Front 30 Rear Cold they gain 4.5 Pounds warm with air. I have never tried nitrogen I understand heat will not change the pressure much.
MT 930 1987 930 - Gone but not forgotten A man with priorities so far out of whack doesn't deserve such a fine automobile. I would rather wake up in the middle of nowhere than in any city on earth - Steve McQueen американский |
Large Member
sorry - I meant to include those facts in my reply
same setup as Jobah - OE '87 bits, Fuzion ZR-i OE sized tires (meh). tx
The set up was checked as cold as I could get it between runs. Most of the time, the car sat for at least 15-20 minutes. After the 29/44 setup. I checked the pressure hot, and it was over 50 in the rears.
krasuskyp - the autocross was at a track in Western Michigan. It was a private event and I had a buddy that was invited, and could bring along a friend. Of course, I jumped on it. I've been on that track before and the weather was supposed to be perfect.
Driver
Heh heh. So that's what we're calling those midweek banzai runs through rush hour traffic, these days?
This is a very interesting and useful thread accept most people posted their tire pressures without saying what size rims and tires they are using.
Big differences between the origonal 16" wheels or 17" or 18" rims and all the tire width, compound, and profile possiblities... Seems to me without that information it makes it, kind of useless... |
Reviving this thread because of the all the possibilities.
I have a Turbo-Look with 205/55-16 in front and 245/45-16 in the rear. Street driven only. I like 29 front/36 or 37 in the rear.
Ray 1986 Turbo-Look Cab White Gold/Burgundy |
Thread Tools | |
Rate This Thread | |
