Ford to Porsche mass air adapter wiring?
Can someone kindly point me in the right direction of a schematic wiring diagram for converting a ford mass air meter to a 1989 911?
Any info about this conversion would be appreciated. I am wanting to convert to mass air becaquse I am making a turbo kit for the Carrera. I have many years experience turbo charging mustangs and have many spare parts like mass air meters and injectors but have little knowledge about the porsche I own.......I don't even know the injector size. Any diagrams or info can be emailed to racinjason12345@yahoo.com Thank-you in advance Jason |
Ingenieur
No joy. The Porsche air meter is a flapper sensor. The Ford sensor is a more modern hot wire sensor. If you wire them together you will just make expensive smoke.
Look here: http://www.carlton24v.co.uk/afmmaf.htm
Thank you for your time, Last edited by beepbeep; 04-10-2009 at 12:51 AM.. |
GREAT!
Now I just have to figure out what wire to connect where...............THANKS! Anyone with a wiring diagram on a working setup? Jason |
