Parts help needed 86 930
Need help in finding a parts source. The EFI installation left me with a blow off valve that vents to the atmosphere instead of back into the air inlet tube as with the stock set up. This gives me that "whoosh" sound whenever I lift the gas and I HATE this sound....(sound like a bus door whooshing open.)
Any idea where I can source a set-up which routes the blow-off valve into the air intake tubing?
Thanks,
Drew
86 930
Autronic EFI conversion
Drew
86 930
Old 04-21-2009, 12:39 PM
Forced Induction Junkie
WERK I's Avatar
Pics of your engine and induction system layout would help greatly in giving you some suggestions.
Thanx
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 04-21-2009, 03:42 PM
I'll try to get some picks tomorrow.
Set up is simple.... the pre-turbo inlet pipe has a simple cone filter on it, no sensors, nothing, just straight to the turbo. I have a Kokelin IC which the current blow-off valve is mounted to on the backside and vents to the atmosphere instead of the pre-turbo inlet pipe. Does anyone make this inlet pipe with an attachment point for the other end of the blow-off valve?
Drew
86 930
Old 04-21-2009, 04:02 PM
Answering my own question...... I now remember that prior to my EFI installation I had the 965 rubber elbow with the molded diverter valve opening in it.
This was not the case after the EFI installation and this is what I need to install.
Thanks everyone for stoking my brain.
Drew
86 930
Drew
86 930
Old 04-21-2009, 05:51 PM
