930gt-40r's Avatar
if it seats fully then yes. If the gear was the opposite direction you would not be able to sit it in all the way.
Kris @ Tech9
86' 930/GT-40R Sold
94' Rustang GT daily (long gone)
2008 C6/Z51 Corvette
Old 05-10-2009, 01:33 PM
Seats perfectly
Old 05-10-2009, 01:58 PM
Turboo934's Avatar
930guy can you post the type number of the 3.0? If it's3.0 turbo motor, it will be 930/50 ROW or 930/51 US for 1976,or 930/52 ROW 930/53 US 930/54 Japan for 1977. The type # is found right side under fan housing.
Old 05-10-2009, 06:23 PM
Had a look but only has engine number in that position, its def a 3.0 as the flywheel is different, it only has 6 bolts securing it to crank.
Cheers
Old 05-12-2009, 11:34 AM
Am I losing it?
Dizzy turn clockwise on 3.0, 3.3 turns counter clockwise.
My 3.0 distributor turns counterclockwise, am I missing something here or is it a 3.3, the flywheel only has 6 bolts and it runs a 6 pin spark box.
Old 05-15-2009, 12:03 AM
Turboo934's Avatar
Did someone change the nose gear on the crank, is that possible? Or does the early Carrera 3.0 turn counter clockwise? I just bought a Carrera 3.0 crank, I'll have to check. Update : Just checked the Carrera 3.0 crank it's dizzy turns clockwise.
Old 05-15-2009, 05:53 AM
Heart is Broken
After weeks of work finally installed engine, filled with gas and fired her up
everything nice and tight, apart from fact i cannot engage any gear when running. The clutch is not engaging, I have good pressure on my pedal and the cable is engaging clutch. I have tried adjusting the cabe as far as it will go but still crunches. Any thought would be appreciated.
Thanks in advance.
Old 06-11-2009, 05:15 AM
Porschephd's Avatar
Dizzy turn clockwise on 3.0, 3.3 turns counter clockwise, so no you can't use it
You could change the gear on the bottom that would work.
Stephen
94 3.6Turbo 6-speed AWD
Old 06-11-2009, 07:01 AM
Hi Guys!
I need your help. We are building 964 turbo and we need a disrtributor. We bought 0237301004 and it fits good but the dizzy goes clockwise and we need counterclockwise. Do you know how to change it or we need another one? I'm I right that we need to find and buy 0237301001?
Old 05-28-2012, 03:59 AM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
