3.0 and 3.3 turbo crossover
Hi all, I recently blew my 3.3 turbo and was quoted 8k for rebuild, I was offered a early 3.0 for a decent price and have bought it. the 3.0 had a lot of money spent so thought it was worth it. It has SC cams a larger turbo and a 3.3 turbo fuel head, it has a few bits missing so i have decided to make one good engine from the 2. Firstly the 3.0 has a different distributer and was wondering if this can be replaced with 3.3 the reason i ask is I am changing engine loom and the 3.3 distributor has a wire coming off which goes to the spark box, the 3.0 doesn't.
Any help would be much appreciated
Old 05-04-2009, 11:39 AM
930gt-40r's Avatar
If you are changing the whole harness, I think you have to use the 3.3 distributor if my memory serves me right. What broke on your 3.3 motor? If the pistons/cyls are ok would you consider using those on the 3.0 motor? Not quite sure about fitment though..
Kris @ Tech9
86' 930/GT-40R Sold
94' Rustang GT daily (long gone)
2008 C6/Z51 Corvette
Old 05-04-2009, 12:08 PM
Good point never thought of that, although this would mean more work than anticipated, would this be a worthwile?.
Old 05-04-2009, 12:27 PM
Crotchety Old Bastard
RarlyL8's Avatar
There is a fairly rare SC engine with the 3.0L short block and 3.3L heads. Ends up as 3.14L
Should be able to do the same thing here if desired.
Old 05-04-2009, 01:17 PM
lite75's Avatar
completely different case, crank, rods, pistons and cylinders. distributor turns the opposite direction too.
75 930, 76 930, 83 SC EFI turbo
Old 05-04-2009, 02:38 PM
Thing to remember is youre running a 6 bolt flywheel and 2.7 crank
To put the 3.3 P/Cs on you need to re bush your small end of the rods to fit the smaller wristpins of the 3.3
You have to change the whole intake if you want to use the intercooler
The distributor runs clockwise and the 76 930 used an 8 pin CD box, I dont know if it was changed in 77, its been a long time since I built a 77 930
Bruce
Old 05-04-2009, 02:39 PM
Turboo934's Avatar
Dizzy turn clockwise on 3.0, 3.3 turns counter clockwise, so no you can't use it
Old 05-04-2009, 05:43 PM
Manassas, VA
lucittm's Avatar
What means "blew my 3.3 turbo"? When you are around a bunch of guys with turbos, all of our engines are "blown" so the description needs to be a bit more specific.
The Porsche engineers probably considered your exact situation and therefore made it as difficult as possible for you to do what you want to do. If you mix the 3.3 turbo pieces onto the early 3.0 (really a bored-out 2.7), you will have a classic Franken-stroker. Electrics, distributor rotation, rods, crank - all of these pieces will cause you headaches as noted above.
I would sell the 3.0 with your parts on it to make it a complete engine and then find a '91-'94 965 engine. It would wake up your car and keep it more "stockish".
Good luck,
Mark
1991 964 Polar Silver Metallic Turbo Coupe
Old 05-04-2009, 05:46 PM
distributor wire
Ok ty for all the replies, I still intend to use the 3.3 wiring loom, I have the spark box so all is good that end, I am concerned with the green wire going to the 3.3 distributor, as the 3.0 does not use this will everything still be ok without using the green wire?
Regards
Old 05-07-2009, 06:46 AM
Turboo934's Avatar
My 3.0 dizzy has a green wire. What is the part number on your dizzy?
Old 05-07-2009, 07:21 AM
distributor numbers
thanks for reply, numbers are:
3.0 no wire 0237301004
3.3 with wire 0237302034
both distributors have an arrow under the part numbers indicating counterclockwise?
regards
Old 05-07-2009, 08:08 AM
regards
Plan B; I plan to use the 3.0 bottom end which was rebuilt with the addition of sc cams, I will remove the fuel head which is a 3.3 and replace with my 3.3 which I know is excellent, as I have already mentioned I will replace the 3.0 wiring loom with my 3.3 as everything matches, just need to know if the distributor will work ok as there is no green wire coming from it and will my fuel head work ok with the sc cams or will work need to be done there.
Thanks in advance
Old 05-07-2009, 09:31 AM
Turboo934's Avatar
What is 930/# on your case? Is this a SC 3.0 or a Turbo 3.0? If it's turbo 3.0 motor the dizzy is #0237301001 or did someone change the gear on that dizzy. I think a 004 is a SC dizzy.
Old 05-07-2009, 12:48 PM
Thats one reason some use the RSR type 12 lead distributer ( Andial used it often as other 12 lead choices were not what they are today ) in the 3.0 turbo high HP ( old school) motors they built in the past, in case you wanted to go retro. Probably less problems and expence just to go to a later motor for the grunt you are seeking.
Anthony @ Voitureltd Bayside WI.
Old 05-07-2009, 02:45 PM
Just a thought, sell off the 3.0, part the 3.3 but keep the distributor. Then find a 91 or 92 C2 Turbo motor and swap it in but use your old distributor.
Or, sell the 3.0 and build up a proper 3.3 /3.4.
If you ever decide to sell you will have a very limited number of buyers that will be interested in a back dated 3.0T.
930's might just turn out to be the next long hood 911S and bump in value when the economy turns. If you go to Frankenstein it will kill you value potential.
Old 05-08-2009, 07:44 AM
Smile
Seems like a plan, unfortunately I do not have the funds, I have to make the 3.0 work for me, The two engines are comparable I have the dyno for the 3.0 and it shows peak at 347bhp. I just need to sort out the distributor issue and I am all good, much appreciate the advise.
Old 05-08-2009, 08:22 AM
the case number on the 3.0 is 930 105 111 0R
Old 05-08-2009, 08:58 AM
started swapping bits today, took out both distributors noticed on the 3.0 it has a plug socket for the green wire, before i removed i cranked both engines and the distributors both rotated the same way. So can i put the 3.3 in instead, also noticed the 3.3 had 2 vacum hoses coming of it but the 3.0 has only 1.
Old 05-10-2009, 10:26 AM
more photos
Old 05-10-2009, 10:30 AM
Dropped the 3.3 distributor in and it fit perfectly and rotated when i cranked the engine, will this work ok?
Old 05-10-2009, 10:32 AM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
