Smart quod bastardus
fredmeister's Avatar
replacing the shift rod coupler bushings
===============HELP ADVICE WANTED=============
I removed the rear tranny shift rod coupler and am trying to replace the plastic bushings that are held in the diecast aluminum housing. I am trying to figure out how to push out the steel pin that is pressed into the splined steel yoke that is captured between these bushings.
I tapped on it hard with a hammer and punch and it don;t budge.
I had researched the forums already with the search feature and cannot find any specific forum post that deals with removing this pin and replacing these particular bushings. I don't have a press at home but a good bench vise and some hand tools.
How do I remove this center pin? Don;t want to break the aluminum coupler housing in the process.
Fred
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 05-18-2009, 03:46 PM
Mr. Fred,
I can't help you with pounding your pin "no pun intended here" but I do have a very good coupler you can have. I just installed my Wevo and a new Stomski coupler. If you get me an address I'll send you my original. Wouldn't want to see you break your pin pounding it and be without a means of coupling.
Cole
Cole - 80 930 "The Old Sled"
Mods: TurboKraft Custom IC, 934 Headers, GSX 61, Zork, Port Work, SC Cams, Air Mod Fuel Dist Relocated, Water Meth Injection, BL WUR, MSD 6530, Greddy EBC, Synapse Bov, Short 2nd & 3rd with 8:37 R&P, Wevo Shifter, Coupling, and Mounts, MTX-L SSI-4, Big Brakes, Rebel Coilovers, Bilstein Sports.
Old 05-18-2009, 05:54 PM
Turbo Hooligan
I put a small socket on one end of the pin to push it through, and a big socket on the other end to let it come out, put the whole assembly into a bench vise, get out the blow torch and heat her up a lil bit. then start sqeezing the vise. it'll slide right out.
D-Zug
Old 05-19-2009, 05:49 AM
I placed a socket just wide enough to cover the bushings open side up on the ground using wood to absorb and then used the punch out with a hammer to push the pin through...
Nothing like using a hammer
Scott
1979 930 - Black on Black and in the woods
"My third child that will cost more in the long run" :shock:
Old 05-19-2009, 05:50 AM
you just beat me out by a min...lol
Scott
Old 05-19-2009, 05:52 AM
