After the next project
x98boardwell's Avatar
Jim
I know they are kind of hard to see but the rubber hoses are already there to protect the lines.
I thought about using the heat on that one tube to help protect it since it will be more susceptible to things. I will see where the oil temps get to and then decide. I most likely will not be tracking the car so it should be ok. Thanks for the tips.
Bryan
Old 05-20-2009, 07:52 PM
A930Rocket's Avatar
I saw the hose wrapped around the braided lines, but was thinking more in terms of a home made grommet.
Old 05-20-2009, 07:55 PM
Jim
Gotcha, I will work on that. I like the idea.
Bryan
Old 05-20-2009, 08:31 PM
Updates
Well,
As of today with Cl8ton's (Rod) help I was able to mock fit the finished product. It looks good. I had to adjust the oil lines off the cooler to accommodate the fog lights.
I have included some pictures of how I ended up mounting them. It may not be the best idea but they are solid. I want to run a protective coating on once of lines and finish restoring my headlight washer system prior to me mounting everything but I'm guessing it should be done this week.
Lastly, I chose to use foam (from Lowe's) between the splitter/spoiler and spoiler/bumper to help reduce vibration and to spread the load over a greater area. I included a picture of the foam on the splitter prior to mating the two together.
I hope you enjoy the pics,
Bryan
Rod had a cameo in this one and didn't even know it.
All finished and ready to show her off. I ended up making a "swirl" pattern on the aluminum due to the fact there was some defects in the surface. I put a wire bit on the end of a drill and made then pattern that way. It looks a lot like when people do it to Stainless Steel. I think it turned out OK.
Old 05-31-2009, 05:55 PM
Wo ist die Rennstrecke?
DonE's Avatar
Very nice. Good job.
Old 05-31-2009, 07:51 PM
Smart quod bastardus
fredmeister's Avatar
looks good.
How did you cut the aluminum splitter to shape? That looks like a thick piece.
I would have still run the oil lines to the front cooler in reverse. The oil system is not really a sealed system like the water in a water cooled car. The oil sump and engine block all get air flowing thru them from the outside atmosphere which mixes with the oil getting sloshed around inside them. This creates foaming of the oil and the air bubbles need to get out somewhere and eventually may start collecting in the upper sections of the oil cooler. Since you have no vents on the cooler, I just thought it might be beneficial to have the return line on the top of the cooler to help remove the air that collects there. In theory, you could form an air pocket in the front valence cooler that would continue to grow from the upper line connection and fill the entire cooler with air until it reached the level of the return line on the bottom of the cooler. Chances of this worst case happening, I don;t know but thats my engineering/reasoning.
Does anyone else agree or can explain otherwise?
Lets see photos of it mounted when done. The paint looks very good.
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 06-01-2009, 06:47 AM
I like the splitter!
Sharpen the edge of that puppy like a blade!
You would be mulching road kill in no time!
GINSU!!!!
Old 06-01-2009, 07:06 AM
A930Rocket's Avatar
Looks great!
Have you thought about painting it black? Maybey use some SEM self etching primer and paint it black.
Old 06-01-2009, 07:12 PM
She is all finished.
Please add your thoughts... opinions welcomed. Thanks to all who helped with this project... especially cl8ton (Rod) here in town.
Regards,
Bryan
Old 06-04-2009, 04:41 PM
Looks great Bryan. How have your oil tempsbeen affected? My cooler is still sitting on the kitchen counter. So are the twin plug heads from 2006. And the ported intake from 2007.... Nice work
82 930 Pearl White 3.3 964 cams, K27 HF, Kokeln, fuel enriched, IA fuel head mod, wur mod, crankfire, 2X plug, Aase worked heads. 1bar, GHL, zork, 23/33 bars, low, loud
Old 06-04-2009, 05:32 PM
It really does look awesome!
Have you considered some time of mesh to protect the oil cooler from stones and debris?
It does look pretty cool to be able to see the cooler though.
Old 06-04-2009, 06:42 PM
Responses
Slyguy, Thanks for the comments. The cooler works great. I have not really been able to drive it much but slow drives around town and it will not even get to operating temp. Get working on those project will yah??
nocarrier, Believe it or not there is a mesh grill there. It is almost touching the cooler and was also painted black. I should be ok. I agree with you I like being able to see the cooler a bit.
Thanks for the kind words.
Bryan
Old 06-04-2009, 07:22 PM
cl8ton's Avatar
Bryan it looks absolutely stunning!
It will be a nice touch for the Historics at Laguna Seca this Aug
Rod...
2010 - 997 PDK, Black on Black, Daily driver.
1987 - 930 Grand Prix White, Not looking for crazy HP, just harmony!
Old 06-04-2009, 07:54 PM
E-85 sippin drunk
turbobrat930's Avatar
Bryan, It looks GREAT!!! Good Job!!!
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-3584RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk
Old 06-04-2009, 11:17 PM
Forced Induction Junkie
WERK I's Avatar
Bryan,
The new look is fantastic, it clearly shows you took the time to do it right. Well done!!!
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 06-05-2009, 07:04 AM
Cowtown10's Avatar
Hey Bryan,
Cool project and super well done! The splitter looks great.
Be interested to hear more in the future on how it performs!
Q
1991 RRC
1995 993 C2
2002 996TT
1984 930 Turbo (gone and missed)
Old 06-05-2009, 07:41 AM
Cymru am Byth
carmad's Avatar
Looks Fantastic, looking forward to the ride to the Historics.
1986 930 (Gone but not forgotten)
1995 993 (Should Never Have Sold it)
2007 BMW 328Xi Sport Wagon
2005 Lexus GX470 Offroader
Julian Williams
Old 06-05-2009, 10:13 AM
It looks great!
IMO if you lower the car some it would look more agressive.
Old 06-05-2009, 06:15 PM
Wow..that looks awesome...great work. Stunning car in every sense.
Yasin
Old 06-05-2009, 07:52 PM
Nice!
Pat yourself on the back.
Old 06-06-2009, 09:15 AM
