AFR's after injector cleaning
Just curious what your experiences have been after having your injectors cleaned. Do you find your AFR's running a bit lower (richer mixture) after a good professional cleaning? I just stuck mine back in and went for a test drive and found that my AFR's are about .75 to 1.0 points lower than pre-cleaining. The things are probably delivering more fuel, and certainly a better spray pattern = better combustion = less oxygen left over = lower AFR. However, it could be a combination of outside air temperature which is currently 97F.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ. |
