Twins are more fun!
EBC on my twin turbos?
Guys, need some input here.
When I was running a single turbo setup, my EBC's configuration had a vacuum line going from the top of the TiAL wastegate to one side of the EBC's solenoid, and the side port on the wastegate was running to another port on the solenoid, with a T-piece with a vacuum line going to the charge air up-pipe. I assume, with the twin turbo's, I just "T" the two internal wastegate actuators together, and run a vacuum line to the solenoid ,and the other port on the solenoid goes to a vacuum port just before the throttle plate? Confusing eh? The K16/16G hybrids were upgraded with new stiffer 1bar wastegates, but I want to be able to regulate boost to ~1.25bar with the EBC.
James Carrera TT (3.3, Protomotive MAP ECU, EFI, GT2 EVO CAMs, Twin Plugged, Twin Turbo's) |
Did you resolve this?
