-   -   TT Conversion - Single or twin BOV's? (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/476837-tt-conversion-single-twin-bovs.html)
JMA-RUF 05-28-2009 12:40 AM
Gents,
I was just wondering, it looks like the 993TT doesn't use, or have dual BOV's (i.e. one for each turbo).
Does the 993TT only use a single BOV post intercooler / pre-throttle body?
I'm trying to decide whether I use dual BOV's or just a single one straight after the intercooler / before the throttle plate.
Discuss please?!?
930gt-40r 05-28-2009 05:58 AM
James,
If going for recirculating setup- I would use the Tial recirc valve (most have not seen one, but it looks like a water bong...) But the reason that I would use this unit is that you can be rest assured that it will flow enough for your two turbos. Now if you want to use traditional porsche aftermarket aluminum diverter valves, I would use one for each turbo because they are small. For reference- I am pretty sure that the 993TT uses two from the factory and am 100% sure that the 996TT uses two as well. I would go with the Tial because it flows more and one recirc valve is less plumbing than two.
JMA-RUF 05-28-2009 06:50 AM
Thanks, Kris.
I actually have two 50mm Tial style BOV's that I was planning to use. One on each turbo charge pipe (pre-IC), but was wondering if that's overkill for a relatively low boost application running 1.0-1.2bar.
I wouldn't mind just having the one 50mm BOV post-IC for simplicity sake, that's all.
930gt-40r 05-28-2009 12:02 PM
It is over kill- but hey who's counting? are you going to run a mass air?
mb911 05-28-2009 12:31 PM
Originally Posted by 930gt-40r (Post 4688498)
James,
are you referring to the Q?
930gt-40r 05-28-2009 12:46 PM
Tial Bong...
This is the "alpha Q"
now tell me this doesn't look like an implement for the consumption of cannabis :D
Now if doing a mass air metered car, this would be a great product.
http://forums.pelicanparts.com/uploa...1243539969.jpg
JMA-RUF 05-28-2009 02:58 PM
I have two of these:
http://forums.pelicanparts.com/uploa...1243547849.jpg
I guess I might as well use what I have. Just think it's overkill having one for each turbo. I would have prefered to use one 50mm BOV post IC, instead of two of these :confused:
red9 08-03-2009 01:15 AM
What did finished set up look like?
beepbeep 08-03-2009 04:25 AM
That takes to much space and will make your motor run too rich if EFI utilizes any sort of air-measuring device other than speed/density. Single bosch plastic BOV works fine as long as turbo discharge is siamesed.
