Order Online or Call:
888-280-7799
McAfee SECURE sites help keep you safe from identity theft, credit card fraud, spyware, spam, viruses and online scams
Porsche | BMW | Mercedes | Audi | Volkswagen | Saab | Volvo | Mini
  Search Pelican Parts:
View Cart | Project List | Order Status |  Help
Any EFI's that works w 3.2 crank senser?
Are there any aftermarket EFI systems that can be configured to work with the factory wire harness on a factory Carrera 3.2?
The trick might be accepting the Porsche crank position sensor system.
Old 06-02-2009, 07:02 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #1 (permalink)
Corrupted by power
IIRC, any will work.
Old 06-02-2009, 08:23 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #2 (permalink)
Thank you. What dose IIRC mean please?
Old 06-02-2009, 12:43 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #3 (permalink)
If I remember correctly.
Lincoln Phillip
87 930 Motec EFI M600 G50/50 in dire need of some TurboKraft love.
Jeep, Chrysler, Dodge, Ram, SRT & AEV Dealer pm me for your Mopar needs.
"the 930 is THE CAR that started my PORSCHE love affair..." Magnus Walker
Old 06-02-2009, 01:24 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #4 (permalink)
930gt-40r's Avatar
The Accel is not good with factory sensor- but could be made to work.
But all of the heavy hitters already have the "62-62" configuration in the setup menu.
Kris
86' 930/GT-40R Sold
94' Rustang GT daily
Old 06-02-2009, 01:29 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #5 (permalink)
It is not likely to find a aftermarket EFI that uses the 35-pin DME connector and pin configuration.
The 3.2L DME uses 2 sensors on the flywheel, the speed and reference sensors. The speed sensor reads the starter ring which is 130 teeth (I might be off by a tooth or two). The ref sensor reads a single marker (set screw) on the flywheel that is positioned around 58deg from TDC. Most aftermarket EFI systems expect a 60-2 or 36-1 trigger wheels, so they will not be compatible with the factory 3.2L two sensors setup.
Depending on what you want to do, there is a way to gain control over fuel and ignition with the factory DME, so going to EFI may not be needed.
John
Old 06-02-2009, 06:18 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #6 (permalink)
Now Available for Ordering:   101 Projects For Your BMW 3 Series 1982-2000  [more info]
Wo ist die Rennstrecke?
DonE's Avatar
I would say the Link ECU could do it. Both triggers (crank/cam) can be set to nearly any config.
Old 06-02-2009, 06:44 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #7 (permalink)
930gt-40r's Avatar
60-2 is what I meant to say.
Kris
86' 930/GT-40R Sold
Old 06-02-2009, 06:46 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #8 (permalink)
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
Copyright 2011 Pelican Parts - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
