Doug Siegel
oil cooler size
Is this a good center mount cooler?
Setrab 172AN12D Oil Cooler 6-1/2"x22" w/ An-12 fittings
Any better suggestions?
88' blk/blk 930: Haltech EFI, Twin Plug, Pauter Rods, Nascar Bearings, custom crank work, dowel pinned case, ported manifold and heads, Kokeln I/C, SC Cams, Turbonetics ball bearing 62-1, BB headers, RARLYL8 Zork, additional 993 oil filter, plx/inyourface gage, RS style coilover, Fikse FM10-17 wheels, TIAL 46mm 1 bar. (where the heck did all my money go?)
Old 06-07-2009, 10:07 PM
wjfk32's Avatar
Greetings:
Personally I installed a 2nd generation mazda rx7 oil cooler..Approx 25-27inch.long 2-1/2thick, 4-6-height.(junk yard-$35-$100).Search-Some guys on the board it. And I tried it out. Brought the lines-bradied & 12an fittings on amazon-cheapest place...Brought the 2 -30mm straight fitings & 2-12an fittings/weld on the oil cooler at BAT-INC-Florida-
I under $200 after I was done....Worth it...INMOP.
Walt
Old 06-08-2009, 09:56 AM
A930Rocket's Avatar
That sounds about what I have. Really no point going bigger because you are not going to get air through it from the smaller air dam opening. -12 will work as well.
Old 06-08-2009, 11:22 AM
I'm using a Setrab 50-150-7612 (I believe same dimensions) and works great.
Old 06-08-2009, 01:58 PM
Send a message via AIM to EPorsche
I have the 272d and would advise that you get -16 connector if possible. Depending on the age of the cooler, it might not be possible to change connectors. This will allow incresed cooling if you go to a bigger engine.
'77 911S w/'81 3.0/MegaSquirt/MSD
'81 911SC stock
Old 06-08-2009, 02:28 PM
Doug Siegel
Can someone tell me how the model numbers correlate with the coolers?
Do some of the coolers vary in diameter internal tubing size?
How much surface space of cooling do these coolers have?
Old 06-08-2009, 03:01 PM
A930Rocket's Avatar
I just checked on-line and I have the (172) A72F225 oil cooler. You can determine the cooling area by L X H = A. For the 172, it's 6.5" x 22.5''=146.25 square inches.
http://64.202.180.37/files/mhd$.pdf
http://64.202.180.37/files/setrab$.pdf
Old 06-08-2009, 06:50 PM
Wer bremst verliert
JohnJL's Avatar
I have the 22x6.5 Setrab or Mocal from BAT with the thermostat that comes with their kit. In what should have been the worst-case scenario (warm evening with extended dyno runs) oil temps never got over 80 Celcius (~175 degrees.) That's with a GT2 oil pump.
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 06-08-2009, 07:37 PM
Doug Siegel
Thanks guys.
One of the reasons I'm asking for diameter size of the tubing and such is because I may try to cut a couple of openings in the stock valance and stick 2 long, narrow, and shallow coolers in there if they'll fit. I need to know how much volume/ real surface are I'll need for proper cooling.
I'm still trying to figure out a way to keep the stock valance. I've got 2 fender coolers already but they ain't doing the job.
I'm aware that space is limited and air space behind the mounted cooler is needed.
We'll see.
Old 06-08-2009, 08:09 PM
There is a way to keep the OEM valance. I don't like any of the aftermarket ones and love the OEM rubber lip. Also kept the fender cooler connected in parallel. Track temps went from 220~250 to 190, keeping the OEM look.
Old 06-09-2009, 04:24 AM
Wer bremst verliert
JohnJL's Avatar
Nice one Miguel.
Mine is behind an MAShaw RSR Narrowbody front spoiler.
You can also solve the flow-through and clearance issue with hood venting. Which is superoffentittengeil.
Old 06-09-2009, 05:11 AM
Doug Siegel
Originally Posted by JohnJL View Post
Nice one Miguel.
Are you suggesting cutting through the wall between the trunk and the valance? If so, to wedge the whole cooler back there or to use a couple of 3" hoses and a custom fab housing to let the air escape?
Old 06-09-2009, 07:53 AM
My installation has 1.5" of clearance between the cooler and the tub = allowing plenty of air flow through the cooler while moving. No tub/hood mods required, only notching of the bumper to to raise the cooler through it keeping the rubber lip position as OEM.
Old 06-09-2009, 08:06 AM
Doug Siegel
Hi Miguel,
I may very well copy your invention, but I'm first exploring some other options. EP Slick had cut 2 large symetrical squares in his valance and fit a cooler in there. With space being so limited, I'm wondering if there are any other solutions.
Anyone put a cooler in the trunk and use air ducting?
Old 06-09-2009, 08:16 AM
Wer bremst verliert
JohnJL's Avatar
yes, search will reveal some very cool oil cooler ducting mods to the front and to the trunk.
Mounting Oil Cooler inbound with exit scoop in hood?
Old 06-14-2009, 08:13 PM
Doug Siegel
Thanks John. Good find.
Hood venting must work brilliantly.
Is there a way to vent the air without cutting the hood?
Old 06-15-2009, 06:54 AM
Doug Siegel
Biting the bullet and buying a RUF style valance. I'm aware that the valance makes it a bit tight for the cooler. Before I purchase a cooler, anyone want to give me a heads up on sizing specific to that valance???
Old 06-16-2009, 04:24 PM
