930 track caster/camber settings
What's the latest thinking on 911/930 caster settings for track use? Less or more? There are advantages to each. I've been looking at caster settings for the Group B turbos or the early 80s which ran to lower caster numbers but they were on bias ply tires. I'm not sure if that makes a difference.
What is the thinking about camber settings differences front to rear for a 911 or 930? I know it's all relative to but was looking for some basic rules of thumb.
I'm cross posting this on the Autox and racing list.
Jim
1980 930
1995 993
Old 06-23-2009, 06:31 AM
My understanding is the more caster you have the more camber gain you get when turning the front. As we are camber limited on 911/930's it is an advantage to go for max camber and caster.
On my 85 3.2 up front I got to about 6.5 deg caster and -1.1 deg camber. Wish I could get more.
Old 06-23-2009, 08:04 AM
DW SD's Avatar
what tires will you run? Usually the tire mfg's offer some specified range for their application. this is a good place to start, too.
Doug
1971 RSR - interpretation
DW SD's Avatar
Also, if you are going to pay for an alignment, it is a good time to consider any other upgrades (like monoball, offset camber plates, which gain you about +1 degree negative camber.) You will hate to pay more than once for a proper alignment and corner balance.
Doug
Old 06-23-2009, 11:17 AM
