electric window issue
My passenger side window stopped working awhile back and neither switch would open it. More recently the drivers side died. I doubt that both regulators are toast so just curious if anyone has come across this. I looked at the relay and doesn't look fried but you never know. Figured I would ask before pulling out the meter. Appreciate the help.
Dwayne
'79 Porsche 930 '71 BMW 3.0CS '88 BMW M6 '74 Triumph TR6 |
Dwayne,
My suggestions would be to ck. fuse, pull switches apart clean and sand contacts, check harness power at drivers door window switch, check harness connector where harness mates with main harness just inside the front trunk near the drivers side hood shock, check harness physical condition inside door,if you have power continue to inner door and remove glass from regulator and check motor with no load. If still no go remove motor from regulator and take it to a small motor repair shop as it could just need cleaning and bushes. If both motors don't run I would take a close look at the cross car harness connection to the drivers door. Cole
Cole - 80 930 "The Old Sled" Mods: TurboKraft Custom IC, 934 Headers, GSX 61, Zork, Port Work, SC Cams, Air Mod Fuel Dist Relocated, Water Meth Injection, BL WUR, MSD 6530, Greddy EBC, Synapse Bov, Short 2nd & 3rd with 8:37 R&P, Wevo Shifter, Coupling, and Mounts, MTX-L SSI-4, Big Brakes, Rebel Coilovers, Bilstein Sports. Last edited by cole930; 07-14-2009 at 01:31 PM.. |
