need help with idle proble <did many many searches with no result
Hi got a idle problem have been using the search function with no result for my problem.
my 89 930 runs great the only problem I have is with the idle . when cold it idles as it should at 1300-1400rpm . once warm it goes down to 1050rpm<I will lower it to 900 once I find the right screwdriver.> if it idles for a while or after driving the car for a while at 60 MPH once stopped the idle will go to around 1500rpm . the only way it will go down is if i put it in gear and press the gas to advance a little.I tried pinching the hose from the intercooler to the AAV and the 2 vacuums to the distributor and it still will not go down . let me know what you all think Thanks Erick |
I was going to say throttle linkage like Mark, or sticking mechanical advance in the distributor. But then I reread your post and you say that it will get up to 1500rpm just sitting idle for a time?
just sitting at idle.can It still be one of the 2 ?
if I stomp it I will go back down but after a few seconds not imediatly
With the engine off (cold as well as hot), fully depress the pedal and slowwwly release it. Then...and this is the hard part....you need to get your fingers down to the linkage near the throttle body to see if it's fully retracted. You might also be able to crawl under the car (after raising it up of course) and grap hold of the linkage rod that runs up behind the engine to the throttle body. If everything feels like it's running freely and not hanging up, then you must be having some sort of intake air leak that is leaning things out (expanding when warm and leaking when otherwise it would seal when cold). Rather strange, but check the linkage first. |
..maybe your deceleration valve has developed a sense of humor in it's old age
I was going to say decel valve
update on the car . set the co at 3 ,when the car sits for like 2-3 min it will accelerate on it's own till 1500 . how do I test that valve?
thanks |
I'm a little confused on the decel valve myself. What I thought was the decel valve, turned out to be the AAV I removed a long time ago.
So where is the decel valve? |
I don't know enough about them, but would think they have a diaphram inside that allows it to open under vacuum. One would think that failure (like a ruptured diaphram) might allow air to flow when it shouldn't. Small pin hold in the diaphram = gradual climb in rpms as more and more air is introduced. Just a guess....Mr. Fairman may have the right diagnosis here. |
You need to get someone to help you,, disconnect the linkage at various parts and figure out where it's sticking. start with the transmission pivot point, then move to the engine point.
In my case a bit of gease was all that was needed.. |
will try the linkage tomorow . can I acces the pivots from under the car?
is there a way to test the valve?by pinching the vacuum to it can I tell if it working? Thanks Erick |
Is this it? The workshop manual calls it the AAV.
http://forums.pelicanparts.com/uploa...1247712414.jpg |
Yep, that would be the dude. Technically it's a valve...either open or closed...whereas what most of us (myself include) call the AAV (for high idle when cold) is actually a regulator (since it infinitely controls - or regulates) the amount of air introduced based on engine and internal heating element temperature.
I swear the manual interchanges the AAV and Decel valve descriptions. |
Yep, that's it . . . the Porsche PET refers to it as the "Vacuum limiter" and it costs over $500 for a new one !!!
My 930 recently began idling very high (1700 or so) and popping quite a bit more off throttle and adjusting the air/idle screw had no effect. I tested the cold start unit and it worked perfectly . . . other previous posts suggested a bad AAV would have these symptoms . . . I have removed it (had to remove the diverter housing to do so - no space to get to it otherwise) and have capped all the associated ports . . . I will put it all back together and test it in a couple of days . . . BTW the AAV was full of black, rusty, murky water (not just a little, but full) . . . it must have been put in a parts washer last summer when it, and many other parts, were at a shop for servicing/powdercoating etc. Several members of this board have removed this unit and say that throttle responce is much improved (at the expense of more off-throttle popping) . . . I'm interested to put this to the test. There are several old threads about running without the AAV in place . . . R |
There might be an even a easier solution. One of the return springs on the throttle linkage has a habit of rusting and breaking. Check your throttle linkage pedestal on top of the intake manifold. Check to see if there's tension on that spring or is if it just sliding around. http://forums.pelicanparts.com/uploa...1247750150.jpg |
Rocket, its hard to tell from the pictures you posted, but your manual may possibly be refering to the AAV, not the decel valve. It is a gold saucer shaped gizmo that looks very similar to the decel valve. The decel valve on my '79 is attached to the factory recirculation valve assembly. Since you've got a long-neck intercooler fitted, I'm betting your decel valve was deleted when the factory recirc assembly was tossed in favor of the 965 style parts. The AAV on my car lives deep in the engine compartment beneath the airbox. It shares its plumbing to the intake manifold with the AAR. |
Now that we've thoroughly hijacked Ertech's original post, hopefully this will give him a few other potential sources of phantom air getting into the intake. That, and/or sticky linkage to cause the high idle symptoms. |
I read (in the Bentley manual?) that the AAV bypasses air around the throttle for a few seconds at startup. Its supposed to shut off as soon as the engine fires and starts pulling vacuum. So, Ertech...any news? |
Thanks all
went today to a reputable Porsche shop .he told me my 89 has a <some sort of accelerator swich on the TB .I reconected the O2 and all fine since .from all I have been reading most say to disconect the o2 .is this a fluke it now works correctly? Thanks Erick |
is the the aux air device the same a decel valve?
if so how do i test it? thanks |
8 hour later and still runs great anyone know why the use of o2 cured the problem???
THanks |
Here is a good, previous thread pertaining to some of the 930's idle/vacuum devices:
http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/473939-rpms-hang-fast-idle.html Ronnie |
R |
| All times are GMT -8. The time now is 01:40 PM. |
