930porsche
930 porsche's Avatar
Blow off valve location
1978 930, where is the best location on a 3.3 to put a blow off valve?[
Old 07-09-2009, 10:21 AM
Forced Induction Junkie
WERK I's Avatar
Didn't your Kokeln IC come with the 965 style rubber elbow and BOV kit? Most people have replaced the 965 BOV and replaced them with a billet type BOV due to reliability concerns.
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 07-09-2009, 11:56 AM
930porsche
No. I just replaced it with a full lenght intercooler. Also my intake pipe is going to my turbo from the rear flare not inside the engine.
Old 07-09-2009, 01:10 PM
930porsche
Is it true that by going outside the left rear flare with a 3" steel pipe to the turbo charger will get better performance than going inside the engine like your picture shows?
Old 07-09-2009, 01:18 PM
A930Rocket's Avatar
I've seen them located on the pipe from the turbo to the intercooler.
Not my car, but a nice one!
Old 07-09-2009, 01:24 PM
A930Rocket's Avatar
Are you just re-routing the pipe or are you EFI and wanting to place an air filter in the wheel well?
The stock pipe might not be optimal, but it works well. Placing the air filter in the wheel well brings up a host of problems (dirt, water, road debris, etc.).
Old 07-09-2009, 01:28 PM
930porsche
I did try that with a 3" pipe with a HKS flange adapter on it. It took a lot of space and was leaking oil everytime the boost was on. I talked to HKS tech support and told me that the BOV had to be between the throttle body and the intercooler. Since the intercooler is sitting on the throttle body, then the location should be on the cold side of the intercooler which is the opposite side of the pipe from the turbo to the intercooler facing and looking straight at the back of the car. What do you think?
Old 07-09-2009, 01:33 PM
WERK I's Avatar
I like the idea of the BOV in between the throttle and the "cold" side of the IC output. The bov will last longer because it operates in a cooler environment. I have seen IC's with a bung welded on the cool side of the IC which the bov can mount to.
Dave
Old 07-09-2009, 01:39 PM
930porsche
For the steel pipe from the intake going into the wheel well to the turbo charger was set up like this when I bought the car 5 years ago. I was just wandering if the air is getting a more even flow than going in through the engine department?
Old 07-09-2009, 01:57 PM
nreed's Avatar
bov
I placed mine between the turbo and intercooler. With my MCU setup, doing it this way provides a better throttle response. ie. the pressure sensor gets much less fluctuations and therefore the MCU is happier. Sure its a little hotter in that location but the BOV can take it.
Norm '86 930
AEM Infinity 6 - Twin Plug 3.6L - DBW - JE Pistons/LN Eng. Cylinders - Pauter rods - GT3 Crank - GTX3584RS - ID1050x Injectors - Ported Intakes - Custom Intake Manifold, exhaust and intercooler - 993SS cams - ECUMASTER PMU-16DL
HRE Wheels 560R 8.5x18 ET25 (Front) 11x18 ET0 (Rear)
Old 07-09-2009, 06:45 PM
A930Rocket's Avatar
Is the BOV like the above an EFI only item? Would a CIS engine benefit from one?
Old 07-09-2009, 07:08 PM
nreed's Avatar
It should work fine on a CIS. Much better than the original stock plastic one.
Norm '86 930
Old 07-09-2009, 07:30 PM
930porsche
BOV location?
Greddy, HKS, etc.. are saying it should be placed between the intercooler and the throttle body. In our case for 930, on the cold side of the intercooler welded with a flange. Is it true?
Old 07-09-2009, 08:42 PM
930porsche
By the way what is a MCU?
Old 07-09-2009, 08:44 PM
nreed's Avatar
Sorry - MCU = Microcontroller unit - ECU = Engine control unit - I use the terms interchangably
Norm '86 930
Old 07-10-2009, 06:18 AM
BOV or CBV can go anywhere after the turbo discharge and before the throttle body. It is preferred to put it as close to the TB as possible but many do not because of packaging needs.
I suspect having it closer to the TB allows faster recovery and closer to the turbo should reduce turbo shock / stall quicker.
On a CIS one should use a CBV style BOV, (compressor bypass valve) as air that has gone through the metering plate must not be vented to atmosphere or the motor will go fat. This can turn the turbine into a jet motor and or shoot even bigger flames.
The exit of the CBV needs to be plumbed back in after the air cleaner and before the Turbo intake.
On my C2 Turbo I revered my aftermarket slide type CBV and set it up so is was open at cruse and idle and only closed on accel. This gave me faster boost. With accel on the freeway I pulled instant .5 bar boost.
Old 07-10-2009, 07:58 AM
Sorry, on a CIS the CBV exit needs to be plumbed in not just after the air filter but after the fuel metering assembly and before the turbo intake.
EFI can mostly be vented to atmosphere except not the best idea if it is a suck through style set up.
Old 07-10-2009, 08:01 AM
930porsche
What is TB?
Old 07-10-2009, 09:34 AM
Throttle Body
Old 07-10-2009, 09:41 AM
930porsche
Where is the CBV on my 3.3?
Old 07-10-2009, 09:45 AM
