2.7 oil return
Hey:
Finally have enough parts to start my conversion. I'm using a BAE connector pipe with a T3 turbo on the driver's side. Should i plumb the oil return into the passenger side cam chain cover?
Would someone out there with a 2.7 turbo post a pic of their return plumbing please?
Pat
'74 911 options delete no sunroof. lowered, swaybars, tie bar, braided brake lines, corner balanced, "s" gauges, 993tt seats, Momo wheel and knob, 993 mirrors, blacked out window trim, H4's, short gearing, S pistons, stand alone EFI, other stuff.
Old 07-19-2009, 02:23 PM
built4sound's Avatar
Just curious, are you using the original Rayjay turbo?
74 911s
2.7 Turbo
Old 07-19-2009, 06:29 PM
Happiest when Tinkering
gsmith660's Avatar
Mine goes into the sump plate.
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go!
76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3
76 Blazer also restored by me
Old 07-19-2009, 07:10 PM
My sump plate is flat, what year is that plate from?
I am using a Garrett T3 TB0339 from an SPG Saab 900.
Pat
Old 07-20-2009, 02:58 AM
gsmith660's Avatar
That is an aftermarket sump plate that Ben had on his car and he welded a drain on to it he sold it to me when he went to a scavenge pump setup You could adapt a fitting to your drain line or I would get a new alu. sump plate and have a welder modify it for you the consensus is that draining back to the sump is better than the chain cover.
Old 07-20-2009, 05:54 AM
Thanks for the tip on the cover. Is Ben the same Ben from M&K?
Is your cover "domed" on the bottom?
Mine is flat. Do you know who made yours?
pat
Old 07-20-2009, 06:03 PM
gsmith660's Avatar
Yes, Ben from M&K and it is domed and Ben made it. I dont know if he has any more but you can get any welder to tig you one.
Old 07-20-2009, 06:24 PM
