Rocket Scientist
Early and Late throttle body comparison
Here is a picture comparing the early and late throttle bodies. Please use it as a reference when discussing vacuum connection issues.
Old 08-02-2009, 08:18 AM
Why the hole on the throttle plate of the 76~79?
Old 05-10-2013, 04:52 PM
Rocket Scientist
I think that is a modification. It is the only one I have seen like that. I have not seen that many of the really early cars though, so I could be wrong.
I presume they wanted to raise the idle with some combination of parts/adjustments that they were using.
Does your car have the hole? Is it an early car? I have seen a lot of the later US cars, and they do not have the hole.
Old 05-10-2013, 06:08 PM
Mine does, it is a 78.
Old 05-10-2013, 09:06 PM
Rocket Scientist
Thanks for the info. Maybe all the early cars had the hole then. All turbos use the same auxiliary air control valve, so maybe it has something to do with the ignition timing on the early cars. Maybe they needed more air to idle at 950 with their ignition timing.
Old 05-11-2013, 03:10 PM
Smart quod bastardus
fredmeister's Avatar
My 79 has the hole. It must be to allow for idle air since the throttle plate is closed completely at idle. This hole and the idle air bypass via the idle speed screw is the only means for the engine to get air at idle.
I removed my Aux air control valve when it started hanging open and readjusted the idle speed screw to idle at 1000rpm after plugging the holes up. Now I just need to rev it a little with my right foot when starting it cold till it warms up enuff to drive off.
It was a California model car according to the engine serial number and the distributor on it when I bought the car.
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, B&B intercooler, Snow Perf water/meth injection, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.7bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 05-14-2013, 09:12 AM
